you wont need to drop the engine to get the plugs out just undo and move the radiator forward and put extension with sparkplug socket then put the ratchet on and you can get them out its a bit fidily but you can do it pretty easy.
fully synthetic and the lowest weight you can get will make the little sucker rev heaps faster!!!
using 5-40 fully synthetic
WOULD YOU LIKE SOME FRONT BAR WITH YOUR FRONT MOUNT
is that ok to use fully syntheic oil, coz the CBR2590 is older than 15 years already, i want to know too, as i want to service my CBR too
Go Motul 5100 it was close to $50 for a 5L at MCA on Parramatta Road. $10 for a oil filter there as well.
2.2L for just oil change
2.4L for oil + filter change
2.7L if you opened up ur engine (which you won't be asking here)
You can use your car jack to jack up the front but i find it easier just leaving it as is and ly on ur back to undo the drain bolt and the oil filter. The jack gets in the way of the oil pan. The oil filter is a cartridge closer to the front tyre with a hex bolt. Drain bolt is a standard 12mm i think.
