[DIY] JDM SIR-G headlights to JDM 96 spec black housing headlight
Geniune ITR 98 spec
My SIR-G headlight
I bought Integra SIR-G nose for my mate to do a JDM ITR conversion, only thing different about headlights is the housing, SIR-G is chrome and ITR 96 spec is black
AIM: Create a copy of JDM ITR 96 spec headlight
TOOLS:
STEPS
Remove the silver clips from the head lights, there is 4 of them
Now starting from the corner of the headlight, start heating it using the heat gun and work your way down
Tape up the area that don’t need painting
Now spray the black paint, after finish painting, remove tape asap, longer you leave it harder for it to come off
Assemble everything back together, head gun around the glue (front plastic cover and headlight housing), push it both together as close as you can, then I use a clamp to clam up the area that needs to be pushed in closer. Head gun the area that is clamp, leave for a few seconds then take it off
Before
After
Picture of the lights on the car
Don't know why the pics go up side down when i uploaded it, this is my first DIY thread so if you guys think its worth a rep point, feel free to rep me
very nice, can i just say that if u have an oven, this will accelerate the process by up to 2 hours.
also best to have used high temp paint, as i've heard the standard stuff will fade over time. haerd, but not seen.
looks good nonetheless
im glad you didnt put the sx lip AND that one on or itd be like yo dawg i herd you liek lips, so i put a lip on yo lip so you can lip while you lip
i didnt want to risk melting the headlights, it then will cost me heaps to get another, rather be safe then sorry
ah very true, considering they are quite rare. good reasoning indeed.
good diy mate rep point for you
pics on the diy jdm itr headlight on the car
how long did it take to use the heat gun ?
not that long, 5 mintues max for each headlights
If u apply heat at the right place then it shouldnt take too long
Well Done!!
Looks Great!!
they turned out very nice indeed looks tops!! and nice diy thread
but i think you kinda killed the whole light where the seal is its all mauled! i think anyone that wants to do this use a oven its the best way takes a bit longer depending on how your headlights are but it will seal up like brand new dont leave the oven on! and you wont melt your headlights just heat it up then turn it off wrap your headlights in a bath towel and chuck them in just open them slowly and bit by bit.
paint it with high temp also when u re seal them do the same put them back in the oven so it gets heated up and the place them together rather using a metal clamp like that one use one of those long rubber ones then clamp the whole headlight and re do it till its tight so the edges will be perfect! me,viet and a couple other done it last time on our old cars which was a sportivo and a celica turned out great and also viet done it to his s2k atm
either way mate good work!
