i think the brightness for those is adjustable with ur console. but i dunno whether changing the bulbs would make a difference as im assuming the adjustment just varies the current which means even if u have a bright bulb, if it receives little current it wont be bright? just a random guess
Well, finally after 20 years. Here's the tyre placard as promised i would upload a pic of
Hey man were did you get it made and how much?
Also did u have to take your old sticker in to them, or just a photo of it and its dimensions, as my new placard has a massive rip down the middle off it..
pm me.
pm me.
It was about 40 each i think. I took a pic of it with measure tape against the sticker as the guy is located somewhere in WA or something.. you can find him on ebay just search tyre placard (on ebay he only sells holdens though, but you can always request)
Hmm... Wonder what i should do with my set of Honda CU2 Euro Luxury 18" wheels with Michelin Primacy HP tyres.
pivot raizin - it more of protection more than anything else description is below
Voltage Stabilizer.
By increasing the capacity of the condenser three-fold (compared to Blue RAIZIN), and decreasing both circuitry noise and high frequency impedance the results have been a more stable supply of voltage to all electronic devices, better gas mileage, and improved torque and audio quality.
A World's First: View Battery Performance via Lowest Voltage Display.
Displaying two types of voltage, both real and Lowest Voltage (world first) at engine start makes it easy to see battery life and loss in battery performance. This also helps to protect against trouble caused by shortages in voltage to various electronic.
3 drive throttle controller
installation - piece of cake since there is harness. dedi at top one install it in 15 minutes. no engine warning come out. no reset of ecu
drive - havent tested yet on highway, i will on this wednesday as i need to see my house builder around bella vista area.
however on the way back home i tried it. cant test on economy range yet i guess the only way i can tell is the mileaga on fuel tank
sport mode, i can feel pick up is a lot easier for the car.
they have range for sport from SP1 to SP7 that you can select. i cant tell massive different from SP1 from SP7. again maybe this come into play when driving on highway and not like 60-70km/h on sydney road
On the CL9, headers were the best mod but unfortunately you can't upgrade those on the CU2. I think an Intake, high flow cat and exhaust should improve things a fair bit. The pivot controller seems really interesting too. Does it work with the CL9 Yonas?
