if its 3 wheeling like i think u mean ur talking bout, then high speed turn, stiff chassis, good camera to take the pic
that shud do it but yeh u need to do it pretty fast
3 Wheeling is when you have 1 wheel lift off the ground.
Where as 2 wheeling is having on side airborne and one side planted.
3 Wheeling usually needs a big amount of space.
Cause you can only do it with high amount of g forces created on a turn.
Its basically gettin some speed. Slowly turning in and making it a sharper turn without over steering or under steering. Causing the body to flex so that one wheel lifts off.
Reason: Corrected. =]
Pics of my car at the last hillclimb I did in Perth.
FF car with a stiff enough rear bar always picks up the unloaded rear wheel on tight corners above a certain lateral load, don,t need to be high speed.
My car has whiteline 20mm rear bar on stiff setting
