Page 1 of 3 123 LastLast
Results 1 to 12 of 29
    Newcomer Array
    Jul 2007
    Canberra
    Accord, s2k now wrx22b
    Vtec kicks in - Rev cuts out
    Hey guys just wondering if you know what the issue with my car is??
    I basically get up to 6000rpm vtec kicks in along there somewhere there and then the car cuts out between 7000 - 8000rpm! just cuts out asif it has just died! instead of going to redline and whining it gets up to 7-8k and just cuts out and throws me into the steering wheel and the revs go back down to 6ish before it goes up and does the same thing! is there anything that would be restricting it? Also idols pretty low asif its gonna stall when i stop at lights or something, but that has gone away since i replaced the battery!
    THanks in advance y0!
    iFlutter
    (edit: I used to flutter =[) Vtakk'n again rofl.
    edit: iFlutter again!! lol
    Newcomer Array
    May 2007
    Sydney
    S2000
    is the car actually warm - 3 bars?
    if you rip it when its cold it will cut it off.
    Newcomer Array
    Jul 2007
    Canberra
    Yeah i had a feeling that was the issue so i let get to 3 bars first (I swear its never on 3 bars, but thats probably coz im in canberra hahah so f@#$^*@#^(#$king cold!!) I have to let it sit there idolling for ages before it goes 3 bars because if i drive it never gets to 3 bars ever.
    iFlutter
    Green block gangster Array
    May 2004
    twin GX160's
    dont rev it hard when the engine is cold
    Newcomer Array
    Jul 2007
    Canberra
    Quote Originally Posted by ECU-MAN View Post
    nah i dont lol, i dont usually even give it a flogging but the other day i was just curious and then it just rev cut me lol
    i was on 3 bars on the temp metre too. just dont get it
    iFlutter
    Aug 2005
    west smeobourne
    AP1 S13
    oil starvation check how much oil u have left
    May 2004
    twin GX160's
    3 bars doesnt always mean your engine is at normal operating temperature.
    it will take a good 15 min of normal driving for the engine to reach normal operating temp in normal conditions.
    so as long you have been driving for a while on 3 bars then it should go happily into VTEC, however if you just got into the 3 bars then probably not.
  8. #8
    Newcomer Array
    Jul 2007
    Canberra
    Yeah its 2 week old oil, at the right level too from the looks of it! and yeah i drive for ages before i actually try vtec lol takes like an hour for my car to get to 3 bars though!
    oh wells.. i'll have another look into it later abit tazed now :P
    thanks guys!
    iFlutter
  9. #9
    if your car is taking ages to warm up then check your thermo stat. it could be stuck open.
    Also, engine wear is most dangerous with cold OIL. When you water temperature rises it will take roughly twice as long for your oil temp to get to that level.
  10. #10
    Newcomer Array
    Dec 2008
    Melbourne
    S2000
    mine cuts out before vtec, isnt it ment to when its cold to protect your engine? as its not engaging in vtec? and its not doing harm reving to anything below that anyway?
  11. #11
    May 2004
    twin GX160's
    Quote Originally Posted by KruZzN View Post
    thanks guys!
    your on the right track, so VTEC should enable in those conditions
    2 test you should do. the 1st one is a globe connected to the solenoid. so you can ensure the VTEC solenoid is being powered
    then connect an oil pressure guage, monitor both while someone else is driving.
    you want to see what the oil pressure does when the solenoid is energised.
  12. #12
    Mar 2006
    Sydney
    doorstop
    what if u just manually powered the solenoid john & did a quick oil pressure check at high rpm in the driveway,would that work?
