help: Eg wont kick over with p73 ecu after b18c swap
ok, swaped my engine, it started and ran fine with the old p28 d16 ecu, got my conversion harness and plugged in my b18c ecu and it will crank fine but wont kick over.. any help?
my cars a b18c sir-g which is the vtir version in japan, but it is a p73 ecu not sure if its off a type r or not. i will have a look at that definatly, cheers
P.S if anyone has any more advice, it is sparking when cranking over, just no fuel.
if your motor has the original dual stage intake manifold the P73 wont run the IAB's in the intake manifold,u will need a P72 to do it or a chipped & IAB enabled OBD1 ecu.
the P73 will work on your motor,it just wont be optimal for it,since its calibrated to run a vastly different motor. honda spent lots of money tuning a P72 ecu to suit your motor,why not use it?
like i said the biggest problem u have is with the intake manifold,if its the original dual stage manifold,the P73 has no output to change the IAB's in the manifold,the P72 does.
