hello all, just curious on some information regarding 96-00 rear civic disc brake modules
I recently bought a kit to complete the conversion (hubs, arms, calipers, lines etc etc)
we got to the stage of loosening off the hand brake lines, draining out a lil fluid when we noticed the abs module harnesses were cut on the conversion set
see as they are a complelely different arrangement to the stock EJ8 drum abs module and as we found EK9 and ITR module (in length and mounting locations purely, the module itself did however line up at the hub)
so my questions are:
*Is the connections under the seat for the abs module the same as the drum brake connectors (orange pieces)?
*will my VTi abs MC and Prop valve be the correct fitment to use with the new rear brakes, or would I have to upgrade to a VTi-R prop valve and MC?
thanks in advance, as usual good info will have a rep point left per response
