Page 2 of 2 FirstFirst 12
Results 13 to 19 of 19
  1. #13
    Mar 2006
    Sydney
    doorstop
    thats what i mean,
    everybody has there own different methods of how they think it should be done,its hard to compare readings,especially when u dont know how correct your gauge is or how well u have it screwed in way down there.
    who knows how honda want u to test against their values?
    if u get a dud reading & your motor is running like shit,then investigate further,if not dont worry about the actual figure
  2. #14
    Nov 2004
    Manly Yo
    ED/EG5/EP3/JAZZ
    Quote Originally Posted by CRXer View Post
    thats what i mean,
    IC
    Just like dyno read-outs
    161.4KW ATW Tuned By TODA
    EG5 JDM B16A SiR-II TURBO
    13.28@106.6mph 2.117 60ft On RE001
  3. #15
    Mar 2006
    Sydney
    doorstop
    exactly
    in both cases,just use the same measuring device,make the test conditions repeatable & dont worry too much about the actual figure(unless its totally absurd),but whether it is going up/down or the same value when testing.
  4. #16
    Jan 2009
    Newcastle
    Civic 97
    ha ha cool thanks guys :P i am just wondering caz i thought i would do it before i put the new computer in it and get it tuned see how she is inside there, hopefully its a bove 150psi then :P
    better to do it warm motor or cold, caz i cant warm my motor up caz i kinda have no headers atm lol
    WOULD YOU LIKE SOME FRONT BAR WITH YOUR FRONT MOUNT
  5. #17
    Mar 2006
    Sydney
    doorstop
    cold or hot,it wont make a big enough difference on a stock motor to worry,just make sure u test all the cylinders under the same conditions,if u get bad results,then investigate further with a leakdown
  6. #18
    Jan 2009
    Newcastle
    Civic 97
    cool thanks i'll let you know what numbers i get going to do it this weekend if i get a chance
  7. #19
    Jun 2005
    Sunny Coast
    boosted dc2...
    make sure the throttle is fully open as well, if it isnt, it makes greater resistance for the air to enter the engine reading in a slightly negative reading.
    the compression test is a guide i would only use to compare each piston to the other to find potential problems. nothing else imo.
    Boosted Integra underway!
