Page 3 of 10 FirstFirst 123456 ... LastLast
Results 25 to 36 of 117
Thread: Buying oil
  1. #25
    Sep 2006
    IVTEC
    received these scans from a friend of mine, not sure wat magazine it came out of but thought id share it here .. and i noe there is a lot of different opinions of oils but atleast this is somewhat closer to just hearing someone say something is good or bad. Royal Purple certainly kept its reputation whether it be by mouth or magazine testing.
  2. #26
    Jun 2009
    00' s2000
    iv ebeen told that the motul 8100 0w-40 is really good
    i've gone through most brands
    castrol 10w-40 semi-synthetic
    mobil super 10w-40 semi- synthetic
    helix ultra 5-40 full synthetic
    and am now trying castrol edge 5w-30 full synthetic
    for me, castrol edge which is the one im using right now has turned out the best, such smooth revving aswell.
    cant say the same for mobil and the standard castrol.
    shell helix ultra is also pretty good
  3. #27
    Sep 2008
    Kermit K20A
    at work whenever a customer asks me about what oil they should be running in their performance car i recommend castrol edge sport, mobil1 or a nulon full synthetic (top quality aussie product)
    if you are going to be tracking it as well i recommend going something like a 10w50 maybe even 10w60 cos the last thing you want is to spin a bearing as i have seen on a BNR34 GTR Nur (owners mechanic used a 10w40)
    Kermit EGK20A
    Winton: 1:35.08
    Wakefield: 1:08.8
  4. #28
    Ninja turtle Array
    Chloe
    Quote Originally Posted by tamay_s2k View Post
    That's probably because the Edge was 1 step thinner than the other oils that you used at 30 weight.
    Stocky CL9 - 1:17.2
  5. #29
    Dec 2008
    S2000
    just buy royal purple lol.. ima do it soon.
  6. #30
    Jan 2008
    port macquarie
    2001 honda s2000 import
    I use Castrol edge 5 – 30 I think its that weight, tried Shell Helix but gets used too quickly, Honda stuff not very good, done a track day with the Castrol and held up great, been using it ever since, everyone should keep an eye on oil levels very frequently and don’t be I tight arse on cost of oils, do it your self and use the best and still cheaper than getting someone else to do it, I am also going to get a magnetic sump plug when it needs to be replaced as well.
  7. #31
    Jul 2004
    I come from the land down under
    What happend to my Honda
    I've been using oem honda oils since i've had my car but my last serviced i changed the oil to castrol edge 5-30. i felt the difference, so much smoother.
    Need Customs Clearance? Look no further!
  8. #32
    S2Krazy Array
    Feb 2005
    Brisbane CBD.
    I use the Edge 0-40 from memory.
    PM's Turned Off
    Prelude - Sold.
    S2000 - Sold.
    NSX - Sold.
    F355 - Coming...
  9. #33
    Dec 2009
    Sydney NSW
    Honda S2000 ap1
    So what would the verdict be for someone that has recently purchased an s2k and is doing their first service since buying the car, any suggestions?
  10. #34
    Ninja turtle Array
    Chloe
    Quote Originally Posted by gamgam View Post
    If your car was purchased used, then it is not really the "first" service. So you can go for any synthetic oil in the correct viscosity range. I'd say try Edge 5w-30 first as it is cheap when on offer ($35-40) and great for the amount of money you pay while protecting better than FEO and all the other semi-synthetics out there.
    Stocky CL9 - 1:17.2
  11. #35
    May 2007
    S2000
    does anybody know what oil hannys use for honda s2000s?
    i knows its ELF. ELF what but
    you guys prefer ELF or castrol
    if u have used both?
    thanks
  12. #36
    Sep 2009
    VIC
    Yellow s2000
    omg s2ks drain oil found myself adding like 1 litre of oil over a 3 week period.... is this normal?
    I gave my car a blanket cause it's a sleeper
    S2000 Loving it
    Teg GSI Went to hell
    CLK 320 Sold
    C200 Kompressor Sold
