Hey guys just wandering if a set of 1996 Honda Prelude front seats would bolt right onto my 1996 Ek sedan? cheers
Originally Posted by Jiztec Hey guys just wandering if a set of 1996 Honda Prelude front seats would bolt right onto my 1996 Ek sedan? cheers maybe, maybe not. unbolt your seats, there are only 4 bolts. take the rails off your seats (should be 4 bolts also) and see if they fit the prelude seats. if they do, then try fit the seat back into your car. if any of the above doesn't work, then its not gonna fit, only way then if to custom weld to make the rails/seats fit. This is your best way, cos i don't think anyone will have an answer for you.
They will not fit even with a rail swap. They are much too wide. Peter
Still here. Still kickin'
go custom, prelude seats look good
I wouldn't bother. They look ok but that's about it. I've fitted one to my cb after alot of stuffing around. The upper support is ok. But the hip support isn't that great. Not that comfy either.
OzAccord.com
http://www.honda-tech.com/showthread.php?t=766603
