Page 1 of 7 1234 ... LastLast
Results 1 to 12 of 73
    Oct 2004
    Sydney - Cabramatta/Liver
    Jazz EVO IX
    Wakefield suspension settings
    Hi All
    Just wondering what toe & camber settings people are using for Wakefield?
    I'm heading out for the first time but was told i should get these adjusted for the track.
    Any other tips would be appreciated
    Evo IX - THE FINAL EVOLUTION
    Stock settings that you use on the street would be fine..
    I wouldn't really muck around with the settings until you can put down consistent times and have abit of understanding of the circuit..
    What I use, 1 mm toe out in front, 0 mm rear, camber front 3 deg, rear 1 deg
    Just watch those tyre pressures.
    MFactory Competition Products
    do you know your current alignment settings?
    are you running semi slicks, full slicks or road tyres?
    B20VTEC - since 2002
    Oct 2004
    Jazz EVO IX
    gonna run street tyres on my first outting, got some semis for my second outting.
    Wanna learn the car first so i don't break something.
    Gonna test those adrealines
    what do you guys recommend for tyre pressure?
    dependign on tyre size (i.e. diameter/width/profile) - tyre pressure on adrenalines could be around 37 to 42ish cold?
    Account Disabled Array
    Aug 2004
    Garage
    i would use semi slicks even if its your first time
    Street tyre pressure around 38-39psi hot
    Semi slicks 34-38psi hot (depends what you like)
    As for alignment, it depends on tyre combo and how you like the car to behave. If you want a neutral feel, 0 toe is fine
    Ninja turtle Array
    May 2004
    Sydney
    Chloe
    I ran 40 psi cold on my Adrenalins. But my car was heavy. Depends on what car you have.
    Stocky CL9 - 1:17.2
  8. #8
    Oct 2004
    Jazz EVO IX
    o ok,
    Civic ek4, KYB adjustable dampener, 5Zigen springs, 22mm swaybar.
    tyres - 195/55/15 adrealines
    semis - 205/45/16 Kumhos
    i dun think i have the room for 2 sets of tyres, was only gonna bring a pair of tyres as spare
  9. #9
    Aug 2004
    Garage
    drive down on the semi's.
    Its only a 300km round trip, wear on the semi's wouldnt be much
  10. #10
    Oct 2004
    Jazz EVO IX
    should i camber them?
  11. #11
    Quote Originally Posted by Limbo View Post
    what does that even mean?
  12. #12
    Oct 2004
    Jazz EVO IX
    should i use camber on my semis?
    Quote Originally Posted by tinkerbell View Post
