Muck around with your setup once you've found a base level of performance. Fiddling with settings now will be pure speculation - drive the track and learn how your car responds to the surface then worry about the setup once you know what you want to change and what you want to achieve. No point worrying about camber now if you get out onto the track and learn your spring balance is completely different to what you want.
If it's your first time on the track, drive smoothly otherwise be prepared to rape your left side tyres.
