My door window moulds are faded and the metal is showing through. It looks aweful from outside and considering Honda have these for $115 each side, I thought a reused can of Matt-black and sand paper is worth a try.
How do I remove this piece?
I assume It's just a matter of removing the inner door skin, then using a flat head screwdriver (wrapped in a cloth) and slowly prying it up?
Are cliping holding it in and when you pry them up will they break? Putting it back on, how are you meant to hold the clips in place from inside the door while you clip the piece back on from the top?
Cheeeers
