I understand where you're coming from OMG.JAI xD, but as long as its a genuine sharing of info it's good for the Honda community.
I'm from Sydney and I have just done my 20K service at Hornsby Honda. I went there because I got a cheaper quote at $211 (comparing with Scott Artarmon Honda which quoted me at around $290). However I must say the service hasn't been the best, among other things they swapped the front wheels with the rear wheels for the tyre threads to be better and more evenly wear out. That's fine, except after the service the car won't go straight anymore, there's a wheel aligment issue which they said it is normal after a wheel swap and I will have to pay $78 to have it fixed. Or they said "they can swap the wheels back to the original position for free and they problem will be gone". I chose the latter option and the car still pull to the left when the steering wheel is dead straight, i mean quite abit to the left.
I call them later that day and explained to the guy that I didn't expect new problems to arise after a genuine Honda service, and that they should have give me a more expensive quote in the first place which covers a wheel alignment process which they knew is bound to happen. The guy said come in on Monday 8:30am and I will do a wheel alignment for you for free.
I went in 8:45am and the guy said they can do it for $45, I just had enough arguments and decided that I will pay them. He said come pick up the car at 1pm. I was like, if it takes that much time why didn't u tell me on the phone this morning? (I called him beforehand to confirm the appointment that morning). And why didn't you ask me to come in at 11pm or sth?
Anyway, this is just my little experience and I'm sure there are many similar or worse expereince out there.
FD1@Cammeray
Originally Posted by ktvin09
....That's fine, except after the service the car won't go straight anymore, there's a wheel aligment issue which they said it is normal after a wheel swap and I will have to pay $78 to have it fixed. Or they said "they can swap the wheels back to the original position for free and they problem will be gone". I chose the latter option and the car still pull to the left when the steering wheel is dead straight, i mean quite abit to the left.
these are purely BS. swapping wheels should not change alignment and they probably have done something they shouldn't.
i'd personally never go back to this dealer.
i'd demand to get the dealer to fix it for free. if i have to pay for alignment, i wouldn't go to the dealers.
Having different tyres on the front than the rears can change alignment.
Even though if they are the same tyre sizes all round, it doesnt mean the diameter is the same.
You can have one tyre with 8mm tread brand new, and another with 9mm. Both having the same tyre sizes. xxx/xx/rxx
If an alignment was carried out with 3mm in the front and 7mm in the rear there is a 4mm difference in diameter.
Rotating that will lift the front by 4mm and lower the rear by 4mm.
Youd think this wont effect anything. But it does.
I aligned my car with 195/55 all round. I changed to 215/45 in the fronts only.
Aligned it perfectly with 195/55 in the rear and 215/45 in the front.
Everything in spec, the steering wheel is off to the left.
I change the rears to 215/45, the steering wheel corrects it self.
But between those tyres there are a 15 or so mm difference. But the steering was nearly 45 degrees out.
Ive had cars come in the dealership with abs/esp light coming on constantly cause they had one different tyre on one wheel.
195/55 with 240 treadwear is different to 195/55 with 280 tread wear. Those are just rating numbers, but most of the time it does indicate how much tread they have. It alters the overall diameter by a c4nt hair.
That's what the honda man told me, that after a wheel swap, the change of thread in tyre would cause a pulling effect. Oh well, what's done is done, it's just that they should have included a wheel alignment in the service in the first place, even if they give me a higher quote.
I won't go back to that dealer that's for sure :P
FD1@Cammeray
I'd assume we're talking about stock wheels/tyres with identical front and rear on same km travel on each of 4 tyres.
Being same size on the same axle, I wouldn't think there will be substantial diff when they swap from front and back. All 4 tyres won't wear the same rate but certainly not enough to make the car to make the car to pull to 1 side substantially.
one time my dads old crv went into service at hornsby, and came out missing the honda sticker on the rear wheel cover...
i mean what the f*ck? talk about random AND dodgy.
ive never had any issues with artarmon and would highly recommend them, and im more than happy to pay a bit of an excess for this... $20 for piece of mind works for me.
Cheers mate, I'll go to Artarmon next time
FD1@Cammeray
