Honda Jazz upgrades
Hi, I am new to this forum and a first-time new car user.
I have a 2008 Honda Jazz Vti. I would like to upgrade a 15" steel wheels to 16" alloy wheels. I want to know what are the things to consider as such warranty issues with honda dealers, quality of genuine honda alloys, car tyre brand, suspension adjustments and so on. Also I have mud flaps on my car and does 16" affect the mud flaps on normal driving.
My usage is day-to-day commute from work to home. I need some good quality tyres in wet weather. Current tyres are not good in this situation.
Cheers
I think that the car need better handling and performance. What upgrades are require to do this? like coilcovers, strut, high quality brakes
To upgrade handling, get some bars(Front, Sway, Rear etc.) + coils. That's pretty much the basics.
I wonder what to purchase on alloy wheels as I am choosing between 15" or 16" ones. Work Emotion CR-kai ones. I am not sure about +40, 44, 37 issue.
which ones are better handling and comfort on 15" or 16"?
15
+40 etc is offset or pretty much how far your wheel sticks out. Too far in and it'll hit the brakes, too far out and you'll rub the guards. For performance 15" is better for performance performance and handling, 16" looks better though.
Cheers
AT or MT?
what tyres are you running at the moment?
Originally Posted by hoey888
AT or MT?
What is AT or MT?
AT or MT?
If you mean AT as automatic transmission. that is what I am using now.
Tyres are using Honda stock ones of GoodYear GD3 but weird size of 175/65/R15.
its ok for normal conditions but not good in wet conditions.
Are Honda 15" alloys good?
I am in Tasmania. Resources are limited to get hold of other than internet purchase.
From the sound of it, being budget conscious 15" is probably the best option as it is readily available, hence the cheapest for tyres.
16" is an awkward size and expensive on tyres so not really recommended. If your looking at 16", you might as well pay a bit more to get 17".
More importantly you mentioned your running 175/65/R15. This means tyre width is 175mm (the width of tyre touching the ground) and 65 is how high the tyre sits relative to rim.
If you occasionally go into the hills in tassie, would recommend getting a rim that allows a 'wider' tyre to be fitted. This allows more cornering speed and stability. most people go for 195 or 205 width tyres
What is your reason to upgrade to 16" rims? For the looks, better handling etc?
Have you consider the price of the rubber for 16" rims? As some might have said, price for a 16" rubber is not cheap. Also, upgrading to 16" will affect the fuel consumption of your car, which means 17" is out of the question. If the reason for changing rims is just for the appearance, I would suggest getting a set of 15" and swap over the rubber. As you did mention that you're using your jazz mainly for daily traveling to work, so I don't see the need for coilovers, bars etc as many other suggested.
