Results 1 to 4 of 4
    Airbag Replacements?
    I recently had an accident and my airbag came out. I've fixed the car and all is left to fix is the airbag on the steering wheel.
    Is there a cheaper way to fix this other then going to Honda to replace it?
    Green block gangster Array
    twin GX160's
    you simply need a new SRS bag and SRS ECU
    Apr 2006
    I'm here right now
    JDM K20A
    Quote Originally Posted by FoCuS View Post
    the cheaper way is to run no airbag, but I WILL NOT do that. Second thing is to find a second hand steering wheel with the airbag is still attached.
    otherwise you will need to purchase the airbag module for the steering wheel. Depending on the car, you might not need to replace the SRS Unit. but after replacing the steering wheel airbag, if the SRS light is still on then you know that u will need to replace the SRS unit as well.
    however, its recommended to replace both of them in one go.
    twin GX160's
    you have to replace the SRS Unit because the SRS light will stay on.
