Results 1 to 7 of 7
Thread: CL9 Spring rate
    Nov 2007
    Blacktown
    04 CL9 Lux
    CL9 Spring rate
    Hey guys,
    did a search on here, couldnt find anything :S
    did a search on google on TSX forums said F 1K - r 3k. ....
    Just wanted to know the factory spring rates on the CL9 so i can compare to the set of coils im getting. im sure they should be stiffer but i just want to see how much lol.
    Thanks.
    8===D
    Nov 2007
    Blacktown
    04 CL9 Lux
    1k front
    3k rear.
    is that right?????
    because the coils im getting at 12k front 6k rear. :S
    massive difference.
    8===D
    Ninja turtle Array
    May 2004
    Sydney
    Chloe
    Front should be stiffer than rear.
    TSX 04-05 is front 5 kg/mm and rear 3.1 kg/mm
    Stocky CL9 - 1:17.2
    According to Tanabe, their NF210 lowering springs are about 10% stiffer than stock. They rate their NF210 springs at 5.6 kg/mm front and 2.5 kg/mm rear
    http://www.eautoworks.com/html/ORD-1-1-1-30710.cfm
    Nov 2007
    Blacktown
    04 CL9 Lux
    very helpful. Yeah i figured front is stiffer because of engine weight.
    so saying that:
    "TSX 04-05 is front 5 kg/mm and rear 3.1 kg/mm "
    Getting Coilovers that the website says
    front: 180L - 12K
    rear: 220L - 6k
    so my ride will be sh!t stiff even with dampening.
    8===D
    Ninja turtle Array
    May 2004
    Sydney
    Chloe
    Quote Originally Posted by mattchuej8 View Post
    so saying that:
    front: 180L - 12K
    rear: 220L - 6k
    It will be stiffer. I run 10 kg/mm front and 6 kg/mm rear at the moment and it is not really comfortable on Sydney roads. It was fine on Melbourne roads. Every speedbump is hell.
    Stocky CL9 - 1:17.2
    Nov 2007
    Blacktown
    04 CL9 Lux
    That wrecks it
    want the euro to still be a little comfortable i dont mind stiffer but the way you describe it especially in western sydney haha.. Would the dampening help if anything?
    8===D
