Results 1 to 9 of 9
    May 2008
    NSW
    Still waiting for it.....
    S2 engine code 60
    Hi alll
    I got a friend that is getting a engine light code 60 on his s2k, has anyone heard of that
    THE BEAST IS SLEEPING
    Aug 2008
    Northern Beaches, Sydney
    S2000 AP1
    I do believe error code 60 is a fault code related to the air pump. Check the fuse and check to see if it's working on start up.
    May 2008
    NSW
    Thanks for your reply what air pump are you talking about
    Aug 2008
    S2000 AP1
    The air pump you hear only on cold start, quite noticable if you have an intake, regardless you can hear it cut out after about 30-60 sec's after initial start up. You can hear a minor whistle when it cuts off. Pump is located in front left hand corner. Front bar will need to removed to get to it. It could faulty, it could be disconnected, it could be f@#ked. Check all options plus check fuse (not sure if there is one for the pump).
    May 2008
    NSW
    Yeah i think your right ill check tomorrow and ill confirm it with you
    May 2008
    NSW
    Quote Originally Posted by JAP-S2K View Post
    Hey mate i check the air pump everything seems to be connected
    i checked the fuse as well its all good
    so i dont noe what is the problem now
    Aug 2008
    S2000 AP1
    is it turning on, at initial cold startup.
  8. #8
    May 2008
    NSW
    Narh around 30 to 60 sec
  9. #9
    Aug 2008
    S2000 AP1
    It could very well be the relay then situated at the front next to the pump, if it's faulty and/or not working properly this code will show. Nevertheless the front bar needs to be removed. I don't think it can be anything else other than that. Hope that helps.
