Page 10 of 13 FirstFirst ... 78910111213 LastLast
Results 109 to 120 of 149
  1. #109
    Oct 2009
    hehe
    hehe
    nah sounds about right, 98mph with 1350 kg car with 150 atw.
  2. #110
    Jun 2006
    K20 DC2R
    launch higher rpm, ride the clutch more
  3. #111
    Feb 2008
    Dc2 + EG
    Car: EG Civic
    Vehicle weight W/O driver: 1000kg~
    Engine/setup/modifications: 11:1 1.8L B16b + toda b cams + i/h/e/s300
    Driven tyre type: 205/50/15 federal RSR with circuit alignment (-4 camber)
    60ft 2.09
    E/T 13.6
    MPH 103.74
    Will be heading out in winter with less fuel for a lower time, this was done with full tank in mid summer.
  4. #112
    Dec 2011
    egg
    Any H2B civic setup times? anyone??
  5. #113
    Car: EK1
    Vehicle weight W/O driver: 977Kg, half tank fuel
    Engine/setup/modifications: Stocko K20a, Hondata
    Driven tyre type: 80% worn Potenza RE002 @ 36 psi (didn't change pressures)
    R/T = .704
    60ft = 2.119
    E/T = 13.318
    MPH/KMh = 107.10
  6. #114
    Car: EG
    Vehicle weight W/O driver: 1020kg minus driver
    Engine/setup/modifications: B18CR with exhaust, header and pod filter
    Driven tyre type: Yoko ad08r 205/15
    60ft = 2.3-2.4
    E/T = 14.8
    MPH = 94mph
    Fair bit slower than I expected (even with the shitty 60 times).
    I guess the car is a bit down on power from where i expected, maybe due to restrictive exhaust and/or factory tune
  7. #115
    Jul 2012
    Busselton, WA
    DECF28R & JB627
    What's minus driver, is thatcwith our without driver?
    SSpamily
  8. #116
    Nov 2004
    Manly Yo
    ED/EG5/EP3/JAZZ
    Quote Originally Posted by Lonewolf View Post
    Car: EG
    60ft = 2.3-2.4
    E/T = 14.8
    MPH = 94mph
    maybe an air flow issue?
    Benny with the same setup used to run 13.8s no problems
    161.4KW ATW Tuned By TODA
    EG5 JDM B16A SiR-II TURBO
  9. #117
    Quote Originally Posted by cbauto View Post
    without driver
    Quote Originally Posted by Lukezen27 View Post
    theres maybe 0.5sec to be gained with a better launch, but MPH is a bit down based on others with similar mods (though most seem to have a tune - could account for the difference)
  10. #118
    Nov 2004
    Manly Yo
    ED/EG5/EP3/JAZZ
    without driver
    No tune for Benny stock B16C7 ECu
  11. #119
    Feb 2008
    Dc2 + EG
    Car: EG
    60ft = 2.3-2.4
    E/T = 14.8
    MPH = 94mph
    Mph is defs down a fair bit, you'd usually expect around 98~mph for standard with bolt ons. What gearbox are you using?
  12. #120
    s80, 4.7 FD i believe
    passed the line @ around 7000rpm in 4th i think
    unsure of the condition/type of cat, and the twinloop may be restrictive vs straight through muffler
