Results 1 to 8 of 8
Thread: b20 blocks
    Jul 2005
    sydney, liverpool
    type r
    b20 blocks
    which one is a good one ? or are they all the same ?
    WTB - B16/18 HEAD
    b20z1 blocks have higher compressions and slightly more hp compared to b20b's
    a better block to start off with, but if you're going to change pistons and rods
    it should'nt make that much of a difference
    Nov 2005
    Adelaide
    XR6 Turbo
    We didnt get the B20z in oz, our equivent is the B20b8 with the PHK pistons which will give you slightly higher comp if you plan to stay with stock internals
    ______________________
    B20VTEC Build Thread
    Jan 2008
    Sydney
    legtec @2psi
    yup B20B8... If you planning on using stock pistons.
    With PR3 head B16a-B18c7 head = 10:04 compression ratio
    With P72 head B18C2 = 10:12-10:23 compression ratio
    There are other factors such as headgasket thickness, how much the heads been decked so dont quote me on specific figures.
    the others are B20B4,B20B3 lower compression and a JDM B20B which depends on year model for difference in compression i think...
    Jul 2005
    sydney, liverpool
    type r
    nice thanks guys
    WTB - B16/18 HEAD
    Jul 2005
    sydney, liverpool
    type r
    is 12.5:1 too high for stock sleeves?
    WTB - B16/18 HEAD
    Account Disabled Array
    Sep 2004
    Sydney
    CT9A
    Quote Originally Posted by datzlr View Post
    Wouldnt say its too high. Personally around the 11:1-11.5:1 for a B20 on stock sleeves is safe.
  8. #8
    Nov 2005
    Adelaide
    XR6 Turbo
    With a good tuner should be fine
