Results 1 to 9 of 9
    Lightbulb DIY: SPOON CF Replica MIRROR Installation on DC2
    Parked my car overnight in Northbridge and someone had broken my passenger side mirror. Obviously someone kicked it coz it had scuff marks and the mirror was on the pavement side. Freakin drunkards... Here's a picture:
    Rang up Honda North to get an OEM replacement, and they quoted me $445 just for the passenger side mirror!!... Time to get Spoon carbon fibre replica power mirrors...
    Step 1: Remove the following screws..
    Step 2: Loosen up the door trimming. (Give it a sharp tug. the bolts should come out).
    Step 3: Use a screwdriver to yank out this cover. You should see a white plug and 3 nuts.
    Step 4: Remove that plug
    Step 5: Use an 8mm socket or wrench to remove the 3 nuts
    Step 6: Press the top & bottom clip to remove the side mirror. An extra hand will come in handy
    Step 7: Voila! Mirror removed.
    Step 8: Remove the rubber lining from the OEM mirror and fit that onto the Spoon mirror
    Step 9: Using 3 screws, fit the Spoon mirror onto car, following Steps 3,2,1, put everything back in place. You're done! Here's the end product
    This is a power mirror which came with the necessary wiring but doesnt have a proper manual for the electrics. I have decided to leave it as it is, but at least i know i've still got the option to connect it to my OEM side mirror switch.
    Review: Perfect fitment! The mirror looks great and weighs really light too! However, the housing for the mirror is facing down just that wincy bit. Thus, i can barely see above the ground even after I push the mirror as far up as i can! Any fellow Spoon mirror users facing the same problem? Please lemme know!
    Dec 2007
    Melbourne
    1992 Del Sol
    you dont have to remove or loosen the door trim pushing the triangle plastic from the top with a flathead will work.
    Quote Originally Posted by SuiJin View Post
    well i did that because i attempted to connect the wires at first, but dropped that idea after that. if you noticed in the photo, my door trimming was still on when i took out that triangle. you will eventually need to loosen up that top corner bit to hide away the plugs/wirings anyway.
    just an optional step if that triangle cover wont budge.
    Dec 2007
    Melbourne
    1992 Del Sol
    Not quite should be okay to tuck without doing that
    did u by any chance had spoon mirrors on ur car before? any issues with the horizon vision?
    Jul 2007
    JDMD15B
    14EGs/8EDs/3EKs
    Passenger side mirror vision isn't 100%, but the blue mirror is awesome, and they are much bigger!
    JDM D15B - you wouldn't understand
    No K-SWAP ? No worries - Unfriend
    Apr 2009
    Sydney
    02 DC5
    how much did your spoon recplica side mirrors cost?
    was it around the same price quoted by Honda?
  8. #8
    Quote Originally Posted by aznalex View Post
    Hondas dont sell the mirrors;
    And you can get them for dirt cheap @ JDMyard (check traders section).
    '12 PWP Tree Hugging Machine
    '99 GPW S2000
    '99 CW DC2R
  9. #9
    yup vision is terrible on the spoon mirrors. just bling factor
