Results 1 to 7 of 7
Thread: OBD2 or OBD1???
    Aug 2007
    Sydney
    Honda Civic Ferio 99
    OBD2 or OBD1???
    Hello,
    I did a search and there seems to be conflicting info. Basically i'm trying to find out whether Civic EK1 with D16Y4 has OBD2 or OBD1 connection in the ECU.
    I'm wanting to connect a Greddy Intel Informeter but that requires OBD2.
    Also does anyone know if i will get Oil temp, Water temp if it does connect?
    Cheers
    Its a OBD1 connector.
    Green block gangster Array
    May 2004
    twin GX160's
    its neither OBDI or OBDIIa or b
    its custom to CXi only using 2 of the OBDI connectors. ECU is OBDIIa era
    Aug 2007
    Sydney
    Quote Originally Posted by ECU-MAN View Post
    Should of add that its a GLi, donno if that makes a difference
    Sorry i don't understand, your saying that its not OBD1 or 2 but has its own custom connection?
    Mar 2006
    Sydney
    doorstop
    for your purposes it conforms to obd2 diagnostics & should have a suitable obd2 port to plug up to.
    what ecu-man is saying is the ecu plugs dont conform to the usual honda layouts.
    stock setup doesnt monitor oil temp,so no,u will not magically gain that function,but u should get water temp.
    May 2004
    twin GX160's
    GLi is the same as CXi,
    and you will not find an OBDII port on them either, just the 3 pin DLC connector and 2 Pin SCS
    Aug 2007
    Sydney
    right
    thanks too all
