CLutch pedal feels rough when disengaging and engaging??
well yeah when i engage or disengage the clutch,i get a rough/sticky feeling? i can change gears as normal, just the clutch feels funny. could clutch fluid be the problem??
Can you describe it better, any extra noises when you do go, when you say stick do you mean rough, unbalanced, grinding at all, and im not referring to gears rather the contact of the disc to the flywheel?
yeah no noise to the clutch, just seem like it grinds when releasing and engaging the clutch
What grinds? The clutch, flywheel, gearbox, pedal itself or the master cylinder?
So many varibles or parts can be involved, it may be worth taking it to someone to look at it for you before you may do yourself more damage not getting it seen to and leaving it.
