Results 1 to 12 of 67
Threaded View
    [DIY] Painting brake caliper
    I think there's already one of these but you can never have too many, here is my version.
    Aim: to paint brake calipers
    Required: degreaser, brake caliper paint, newspaper and masking tape. this is the paint and degreaser I used.
    Step 1: Jack up the car and take the wheel off and this is what you have
    Step 2: Give the calipers a clean by spraying it with degreaser and let it dry up or wipe it off.
    Step 3: Use newspaper and masking tape to mask off all the parts that you don’t want paint on. You can use bits of newspaper to fill the holes up.
    Step 4:Spray the brake paint on the caliper giving it a light even coat. Let it dry a bit for 10 – 15 minutes. Give it an additional 2 to 3 coatings with 10 – 15 minutes in between. I’ve painted it without doing the pad plate thing before and thought that it didn’t look as nice/right so I sprayed it as well.
    Step 5: Take off all newspaper and tape, then put the wheel back on. Repeat for the other three wheels.
    Before
    After
