When buying...
What are you looking for when you're inspecting?
Dints? Cracks? Rust? Anyone have a comprehensive list I could have a quick glance over?
Yes, I'm a noob still.
Edit: Could an admin please move this to the noob section. I forgots about it. Sorry.
Well if u use the search button u will get **** loads of threads answering your question. there was a thread with a big list of what to look out for, was really good, but i can't find it, haven't since for months..
but neway
keeping on topic, how do you go about trading a car? do u just fill out eachothers rego slip thingo?
**** if I know, LOL That's probably another thing I should look into....
Inspection checklist
Inspect in bright light and when it's dry
Accident damage or rust
Check inside the boot, the floor wells, doors and lower sills for red or other dark stains, dimpled or bubbled paint. Use a soft fridge magnet to check panels for plastic body filler.
A vinyl roof may conceal rust or other damage.
Hail damage
Found mainly on horizontal panel surfaces (eg, bonnet, roof, boot lid). If hail damage is evident, check with your insurance company - they may not insure the car until it's fixed.
Panel fitment
Loose panels may indicate accident damage or that the car has been regularly driven over rough roads.
Doors and boot lid/tailgate
Catches should close firmly. Rubber seals can perish over time.
Paint
Look for colour variation, overspraying, dents or ripples.
Upholstery, trim and carpets
Check for wear and tear.
Engine number and VIN (vehicle identification number)/body number
These numbers must match the numbers on the Certificate of Registration. Check for signs of interference - scratches, grind marks, drill holes etc, as they could indicate illegal interference with the numbers.
Year and month of manufacture
Check these are as advertised by inspecting the compliance and/or build plate (compliance plates are fitted to most cars made for Australia since 1970; usually attached to a panel in the engine bay).
Engine appearance
Build-up of dirt or oil may indicate mechanical problems or poor maintenance.
Engine oil
Dirty/thick oil and a build-up of sludge in the engine may indicate a lack of maintenance. Grey or milky coloured oil may signify the presence of water, which can indicate serious engine problems.
Engine at idle
Listen for irregular running, or any knocking/rattling noises.
Oil fumes
Remove the oil filler cap while the engine is idling. Fumes may signify worn piston rings or cylinder
Radiator coolant
Should be clean and brightly coloured. Oil in the coolant may indicate a cracked cylinder-head or a leaking gasket.
Radiator cooler fins and core tubes
Check for corrosion or damage.
Battery and mounting platform/bracket
Check for acid corrosion.
Tyres (including the spare)
Uneven wear may indicate worn or misaligned steering or suspension.
Oil leaks
Check the engine, transmission, axles, brakes, power steering and shock absorbers.
Exhaust system
Fumes or excessive noise indicate holes or rust in the pipes or mufflers.
Seat-belts
Check that the belts are not frayed or damaged, and that the belts, buckles, adjusters and child restraint anchorage points are in good condition.
Lights
Check the operation of all lights, both inside and outside the car.
If the vehicle is fitted with ABS and/or SRS (air bag), check that the dashboard warning light/s illuminates for a short time when the ignition is turned on.
Equipment and accessories
Check airconditioning, ventilation fan, electric windows, sound system, etc. Inoperative items can be expensive to repair or replace.
Jack and tool-kit
These items should be in place and in serviceable condition.
IMPORTANT: Before taking the car for a test-drive, check with the seller about your legal liability if an accident should occur.
Steering
Excessive 'free travel' or wandering on straight roads can indicate worn suspension or misaligned steering.
Brakes
The car should stop smoothly and in a straight line. The pedal should not sink to the floor or feel spongy and the steering wheel should not vibrate.
Exhaust
Blue smoke indicates oil is being burnt.
Engine
Should run smoothly (accelerating, decelerating and cruising) and the water temperature gauge should stay in the 'safe' range. Rattling or knocking sounds could mean incorrect tuning or excessive wear.
Transmission
Gear changes (manual or automatic) should be smooth, without any rattles or knocking noises. On front-wheel drive vehicles, these noises could indicate worn constant-velocity joints.
Suspension and bodywork
Listen for rattles when you drive over bumps.
Handy phone numbers
NRMA Vehicle Inspections - 13 11 22
Get a thorough report on the car's mechanics and condition from our experts at NRMA. Vehicle Inspection bookings can be made seven days a week, between 7 am and 10 pm for Sydney, the Central Coast, Newcastle, Wollongong and Canberra. In country areas, phone 13 11 22 for your nearest NRMA inspection service.
RTA - 132 213
Check for stolen parts, that the registration is current and that the seller is the registered owner. Visit the RTA website or e-mail the RTA.
REVS - 1800 424 988 or (02) 9633 6333
Check no money is owed on the car. Have the Certificate of Registration handy when you call. Visit the REVS website or e-mail REVS
do this and you will be fine!!!
