Results 1 to 12 of 14
Thread: 300K EG Service
    Nov 2005
    Bogan from Logan
    EG
    300K EG Service
    My EG4 hatch recently died with a busted Water Pump. It's at 315k at it's well overdue (+10k) for a major timing belt change.
    My question is, while my mechanic is doing the timing belt and water pump, is there anything else that should be done? Will the 'cam belt major service kit' have everything needed? I figure at 300k, there's a couple extra things that might be due.
    Thanks,
    Matt
    Mar 2006
    Melbourne, Mitcham
    EG3
    Ask him to contact you if there is anything else that needs to replaced whilst he is doing the belt, might wanna get all the belts replaced while you're at it too
    Why hello there
    Mar 2007
    www.letusdrive.com.au
    D15B7 YOOOOOO!
    cam seals, timing belt, tensioner, the service of course,
    Check out my build thread EGB16T. http://www.ozhonda.com/forum/showthr...build../page14
    Check out my for sale thread constantly updated with b series/ eg parts!
    Wakefield Honda Nationals First Timer : na-118 EG b16 1:16.4900
    Sep 2007
    CQ
    Civic
    worth seeing if the oil pump seal is leaking as well as the sump gasket while you have ample space then
    WTB: EK oem JDM Visors
    I love J-Cups
    Nov 2005
    Bogan from Logan
    EG
    Quote Originally Posted by shadou View Post
    That's my question, what are the other belts.
    Mar 2007
    D15B7 YOOOOOO!
    lol air con fan belt?
    Oct 2009
    Civic
    might want to change the fuel pump, maybe bottom end bearings?
    Mar 2006
    Melbourne, Mitcham
    EG3
    From memory 2 accessory belts: p/s and air-con.
    Why hello there
    Aug 2006
    97 Del Sol
    At 300000 why not just swap out the engine while your at it?
    Jul 2007
    JDMD15B
    14EGs/8EDs/3EKs
    ^ Because some people don't have the time or money for that.
    Feb 2005
    GD1, EK4R,
    Quote Originally Posted by .:Thrasher:. View Post
    care to elaborate on bottom end bearings?
    IJOEYI
    0o0 whats that... a b20 aye?
    Sep 2007
    CQ
    Civic
    also just another thought (as I've had to do it to mine recently) tie rod boots and tie rods in general, see if the boots are worn (ie. leaking fluid from the front) $45 a boot and $170 a rod
    lol, sif change the engine or bottom end bearings if it's not needed, that's rediculous, easy get 400,000kms out of them in Northern America driving thro snow and shit, OZ is easy conditions
    I love J-Cups
