Page 1 of 2 12 LastLast
Results 1 to 12 of 13
    Dec 2004
    Sydney
    EG5 + 10' Swift
    eg6 climate control compatible with eg4
    as title says.. is it direct plug and play??
    or does anyone know if i can buy the adjustable switch for the temperature by itself? as my one has snapped off and its really hard to move left and right to adjust temp..
    Oct 2006
    Melb
    P1.5 460F/350R
    no its not. you need to have the heater control from eg6.
    the temp slide lever on eg6 is not mechanical like audm.
    audm ones is hooked with a wire. (needs abit more force to move)
    eg6 one controlled electronically. (smooth levering action )
    i hope that makes sense.
    yes you can buy the climate control unit by itself and replace that.
    im not sure if you just want to replace the lever, or the whole climate control unit.
    i think it's alot easier to just replace the whole unit.
    audm unit might cost $50-150, depending on where you buy (rip off wreckers or whatnot)
    S P A M | W O R K S
    Dec 2004
    Sydney
    EG5 + 10' Swift
    thanks for the info... if i can im only after the lever itself as my unit stil works perfectly fine just dat its hard to adjust since its snapped..
    Oct 2006
    Melb
    P1.5 460F/350R
    Quote Originally Posted by VTC-8OY View Post
    you have no idea how hard it is to take the unit out.
    S P A M | W O R K S
    Dec 2004
    Sydney
    EG5 + 10' Swift
    lol u have no idea.. ive taken it out before already few times, ive got small screwdrivers to get to the screws and i know exactley where theyre located.. its not hard after the first time.
    Nov 2003
    Tasmania
    Honda Corolla G
    JDM Climate control also lights up amber haha.
    I've got the whole swap for sale if interested.
    Oct 2006
    Melb
    P1.5 460F/350R
    sorry i didnt know youre such a pro
    S P A M | W O R K S
  8. #8
    Newcomer Array
    Jun 2010
    Melbourne, Vic
    EG4
    my arm lever for the hot/cold has snapped off too. I went to the wreckers the other day and pulled the plastic arm bit arm off...but it was a bitch to get out..and we broke the surrounding plastic unit.
    So...I have no idea HOW to get the old plastic arm out of my car and put the good one back in without breaking the surrounding console? -_-" any tips??
  9. #9
    Feb 2005
    Perth WA
    EG5.9, EF9, EL2
    care to share ? i've had a JDM climate control unit sitting on the shelf for like 3 years but for the life of me I cant get the old unit out.. cant get teh stoopid aftermarket CD player out either
  10. #10
    Aug 2009
    2014 NSX
    Quote Originally Posted by jusybabe View Post
    happen to me aswell, i was planning to super glue the level back in LOLOL
  11. #11
    Jul 2006
    JDM PARTS BRISBANE
    EURO LUX
    it has screws at the back of the unit
    if you can get a screwdriver behind the unit it is easy
    then it slides back out
    easy to just take dash out and acces the screws that day
    really depends how handy you are with the screw driver
  12. #12
    Jul 2009
    Melbourne West
    Yellow EG =D
    Quote Originally Posted by 90LAN View Post
    another way is to remove the plastic cluster piece. and access it from the top.
    WINTON PB - 1:48.9
    EG5 1.6L SOHC
