Results 1 to 8 of 8
    Sep 2005
    Brisbane
    Integra DC2
    B18c Turbo Engine holding back?
    A mate has a b18c turbo,
    After 6 grand the car splatters and holds back.
    Would this be because the obvious reason that he needs a tune or is there something else he is missing that could be a easy fix?
    Ozhonda Supporter Array
    Jul 2004
    Brisbane
    MV Agusta F4
    If its obvious it needs a tune then it needs a tune.
    Fact is it could be anything cause we don't know anything about the car.
    $6k = $0 if crap parts were used and no one knows what they are doing. You could easily start from scratch again.
    Could be a easy fix or a big fix. What is it actually doing and can you advise what the setup actually is?
    Deano.
    Jan 2008
    sydney
    s2000
    i think he means after 6000rpm it splatters and holds back
    Apr 2007
    Sydney
    EP3
    Many reasons dude!
    Is it running a tunable ecu? Otherwise It'd might be a good start!
    Turbo + no tune = stupid questions on OZHONDA!
    Dec 2005
    Point Cook, VIC
    EK1 CXI
    like above need more info about the car and setup..........
    if it has larger injectors it will cause it to cough and splutter on a stock ecu.....
    Oct 2004
    Sydney - Cabramatta/Liver
    Jazz EVO IX
    There are alot of things that can cause that.
    But sounds like the car is misfiring or something
    Are the sparkplugs fouled?
    Evo IX - THE FINAL EVOLUTION
    Oct 2006
    Brisbane
    Lawn mower
    ^^ I would be looking at ignition problem also.. Check leads, spark plugs, and give dizzy cap a clean on the inside..
  8. #8
    Ninja turtle Array
    May 2004
    Sydney
    Chloe
    I'd get the car tuned/retuned.
    Stocky CL9 - 1:17.2
