OK in this little DIY, I will demonstrate how you can change your Recaro Type R seat rails from either Integra to Civic or vice versa.
why .. ?
The Integra and Civic EG share the same floor plan and have ecactly the same seat rail mounting locations. What this means is that you can have rails to fit both cars. Now if you have an EK civic, then no other rail will fit other than EK.
I am doing this to show how you can change the Integra rails on a set of recaros to a set of Civic EK rails.
What do you need:
A socket set to unbolt the 4 nuts which hold in your seats,
A little spanner to unscrew the yellow screws (6 per seat) of the rails
Firstly, the seats:
Here are a set of recaros without the rails.
Here are the rails:
Step1.
Turn the seats over and start unscrewing. The seat on the right is with the rails attached and obviously the seat on the left is without.
Step2.
By looking at this picture you will see that there are 3 hole which connect the rail to the recaro. *Please Note* Every Recaro seat from either a Civic Type R or an Integra Type R are exactly the same and the holes are all in the same position. i.e. in the pic below you will see me lin eup the new rail to the seat for the civic.
Step3.
Make sure you have everything all there. In the pic below you will see a breakdown of the rails and the screws required.
In all hosesty, its is as simple of unbolting the rails that dont fit and replacing them with those that do.
Step4. Place the Recaro with the new rails to yor car.
Step5. Bolt the seats back up and be merry
If yiou have any concerns please drop me a PM or ask.
