Results 1 to 11 of 11
    Nov 2005
    Sydney
    DC5R
    DC5R - Major service question
    Hi all,
    Got my 100,000km service for DC5R and was told by Hanny's that the following will be changed. I wanted to save money by purchasing my own products and was wondering if i'm missing anything from the list.
    - Spark Plugs (NGK Iridium Sparks (ZFR6FIX-11))
    - Engine Oil (Castrol Edge 5W-30)
    - MTF
    - Coolant
    Furthermore, was wondering if the ZFR6FIX-11 spark plug is compatible with the k20a on the DC5R. Will I just need the 1 spark plug or a set of X?
    Much appreciated
    Ninja turtle Array
    May 2004
    Sydney
    Chloe
    Are those plugs the right one for the K20A2? The NGK part finder lists IFR7G-11KS instead.
    You need 4 spark plugs. Double check if your fuel filter was changed at the 80,000km service.
    Stocky CL9 - 1:17.2
    Newcomer Array
    Dec 2009
    Brisbane
    S
    ull need 4 plugs. 1 for each cylinder..? and really a 1.1gap?
    im still getting my head around using such a wide gap, after using 0.6 with evos and GTRs lol
    Mar 2006
    australia
    Honda Lead
    where abouts did you get the info for using ZFR6FIX-11 plugs?
    i can only find IFR7G-11KS listed now for k20a. The ones i pulled out of mine are IZFR6K11.. maybe they are old discontinued ones.
    Quote Originally Posted by qstoria View Post
    Well the obvious difference between those two plugs you've mentioned there is the heat rating (7 being colder of course), and NGK rarely discontinues plugs. Also, don't get MTF off the shelf, you're better off buying the OEM transmission fluid.
    Jan 2008
    John St, Cabramatta
    DC5R
    I'm looking at my log book now for 100K service... mine jsut replaces the engine oil and filter and spark plugs (type s only)
    This is for an 05 Type S.
    as a heads up, my 80K service was 880 dollars **** YA!
    it looks like at 80K and 120K, they do the semi major services !
    Newcomer Array
    Mar 2009
    Integra DC5 Type-R
    should clean the air filter, need to do the power steering fluid so flush and change that, an pending on how much detail you wanna delve into lube RH + LH dool glass chanels i generally do i every 5000 now cos i didnt for a when i got the car and turned my tinting to shit an puts the strain power window motor etc, an marcis is right you need 4 spark plugs make sure u dont skimp out cos the cars gonna hate u if u do! hope this helps, oh and reckless is right! but depends on how much ur mechanic hates u an want to charge you...i got mine done for $410 by a honda specialist so dont stress to much
  8. #8
    Newcomer Array
    Mar 2009
    Integra DC5 Type-R
    forgot to add the final word on the spark plugs, specs are as followed:
    Type R model use either:
    NGK: IFR7G-11K or DENSO: SK22PR-M11
    Except Type R models use either:
    NGK: IFR6K-11 or DENSO: KJ20DR-M11
    hope this helps
  9. #9
    Apr 2010
    Integra DC5 Type R
    Are the original spark plugs ont he DC5R NGK iridiums? (IFR7G-11K).Picked up a DC5 today with 86,000kms on the odometer and looking at the spark plugs they had that part number and wasn't sure if that's the original sparks.
  10. #10
    Newcomer Array
    Mar 2009
    Integra DC5 Type-R
    yeah thats the ones... well thats what i have and thats what it says to use in your log book.
  11. #11
    What spark plugs did u end up getting? Can we use NGK iridiums: ZFR6FIX-11 in K20A (EP3R)?
    Rep my posts if they are helpful!
