Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 27
Thread: Itb's
  1. #13
    Sep 2006
    Out in Nature
    91 eg5 b16a
    Quote Originally Posted by AXS View Post
    might want to do a little head work and a full aftermarket ecu to tune, then ul feel the real power in the ITB's
    Gotcha!
  2. #14
    Sep 2006
    Out in Nature
    91 eg5 b16a
    Quote Originally Posted by EKhatchguy View Post
    You would probably blow your motor. The ITB's allow for more air to rush in at once. With stock fuel maps/ignition timing, you'll run extremely lean and bye-bye motor.
    I see,ah ha.Thanks mate.
  3. #15
    Newcomer Array
    Feb 2008
    ferrari 328gts, sw20 MR2
    if u add ITBs onto a stock engine. how do u expect it to run at all ? (map/afm will not work)
  4. #16
    Feb 2006
    sydney yo
    green whip!
    vacuum box
    it'll probably run, just barely and probably terribly too
  5. #17
    Sep 2006
    Out in Nature
    91 eg5 b16a
    Like DYNALL'S?,then it will run?
    Word!
  6. #18
    Feb 2006
    sydney yo
    green whip!
    no he's just got an airbox.. vacuum box is just something to run all your vac lines to
    i.e. 1 from each tb, to brake booster, map sensor, iac, etc
  7. #19
    Nov 2006
    Brisbane
    Civic EG Si Hatchi
    what if you only work the head, and leave the bottom end standard? would that yeild a good power increase?
    [h=Massive EG6/DC2 Part Out (majority brand new)
    http://www.ozhonda.com/forum/showthr...y-brand-new%29]2[/h]
  8. #20
    Feb 2006
    sydney yo
    green whip!
    the way i see it, itb's aren't about making power
    they're about response and shifting the power band to however you like it
    mid range ftw
  9. #21
    Account Disabled Array
    Aug 2004
    Garage
    Quote Originally Posted by beeza View Post
    Can I simply install a set of itb's on my automatic d16y4 without tuning?
    Just reset the ECU and go?
    Brett.
    It will run on the stock ECU, but its best to get it tune
  10. #22
    I forgot to mention when it gets tuned, I've been told that you have to go to a tuner that knows ITB's apparently if you dont tune it properly, the butterflies of each body doesnt open properly.
    :x thats as far as I know. Can anyone confirm this?
    '12 PWP Tree Hugging Machine
    '99 GPW S2000
    '99 CW DC2R
  11. #23
    Mar 2008
    Sydney
    Bangbus
    All depends on the engine setup, ITB setup, etc.
    My JDM B18C with A-sport ITB's ran fine, and idled perfectly on a stock DC2VTIR ECU. You could feel power loss higher up on the stock ECU though.
    Tuning was fiddly, took about 5-6 hours but the end result was fantastic.
    Actually idled better on the stock ECU than the tuned Hondata
  12. #24
    Wow really better on stock ECU than the Hondata? D:
    '99 GPW S2000
    '99 CW DC2R
