I had this problem too... Thought I'd save $100 and do it myself. It is 99% chance door lock actuator.
You need moderate hand skills, basic tools and allow for 2hrs (should only take 1 though)
The diagrams in this link were invaluable when pulling off the trim:
http://www.ozhonda.com/forum/showthr...light=actuator
What to do:
- Remove door trim (with window down)
- Wind window up
- Remove the 2 screws at the back of the door and other screws, disconnect rods
- Withdraw complete door lock assembly
- Disassemble enough to remove and replace actuator (not too hard because the plastic is flexible and is mostly held with clips)
- Reinstall door lock assembly, lower window, reinstall door trim.
- Laugh at Honda and buy yourself a couple of cases of beer with the money you saved
Things to watch out for:
- Have a few small sized flat blade screwdrivers so you dont use the wrong size one and crack something
- Wrap electrical tape around your flat blade screwdrivers
- Take care removing the silver cover - do it in the order shown in the diagram.
- I COULD NOT remove the passenger side window switch... I chipped it and cracked it but still could not get it out. I recommend removing the door trim with window switch connected and disconnect plug from the back.
- The screws at the back of the door (that retain the door lock assembly) were very tight - don't strip them with the wrong size screwdriver. I got a #3 apex bit (from a drill) and put it it a 1/4" socket and used a ratchet to remove them.
