Results 1 to 11 of 11
Thread: Bike nub
Hybrid View
    Bike nub
    I'm a bit of a bike noob n just wanted a few questions answered.
    when looking for a bike should i be fussed by: rebuilds, imports, mod's and roughly how much mileage is appropriate for a bike?
    currently looking at the zzr250, zxr250, or cbr250RR?
    opinions fellaz?
    cheers!
    Jun 2004
    Sydney
    GSi
    Cbr... Kms don't really matter just check the bike for overall condition as you would a car pretty much. Check the records and servicing from the seller.
    .: I Heart Honda :.
    Quote Originally Posted by Lepperfish View Post
    man i had a bloke at uni, bit of a bike nut tell me: that 30km is the equivalant of 100k on a car.
    having said that all cbr's out there, have decent mileage on them so i dont know what to believe lol.
    Jun 2004
    Sydney
    GSi
    Quote Originally Posted by mick123 View Post
    My Integra Type R is coming up to 100k km. So what? Does it mean it's magically going to die?
    .: I Heart Honda :.
    nah not saying that at all, but an ITR with 70K compared to an ITR with 250km's say.....they arent gna be in the same of nick if u get what im tryna say?
    thanks nonetheless i get what ur tryna say
    Jun 2004
    Sydney
    GSi
    Or you could go buy a new ninja 250 or hyosung thing...
    .: I Heart Honda :.
    Moderator Array
    Jul 2004
    Sydney
    s2k,ED,EG
    Like Lepperfish had said check for overall condition of the bike such as leaks and stuff. I've got 2 bikes which is for sale at the moment which is something you want as well feel free to PM me if your interested.
  8. #8
    ...ZzzzZzzz Array
    Aug 2005
    Pushbike...
    Ignore most of the km's thats are shown on cbr250's and grey imports - I am yet to see a cbr250 that has its odometer digits line up straight... I wouldnt let grey import km's bother me as its the age of these vehicles which you need to be wary of
    Some quick tips;
    * General - Ask seller for reciepts of work done / service history / parts bought - I usually tell someone cares for their vehicle by the way they keep their bike clean/well serviced.
    * Tyre condition - does the rider use full use of the tyre (ie to the edges = good), how much tread is left - is it even wear? check the psi of the tyre with a digi meter if you can get one, check for tyre bits under the rear arch - could be a sign of burnouts and wreckless riding
    * Motor - check if it has been warmed up pre-inspection by feeling as close to the exhaust manifold as you can, usually a sign that its got rough cold start. Does it need excessive start up time on choke? Check for wires or holes through the oil dip stick (bit you hold/screw) as this is race regulation and shows sign of trackbike
    * Intake/Carbs - does the bike rev freely? are there flat spots in the rev range?
    * Frame - check for cracks in the frame and swingarm
    * Gearbox - is it easy to change gears? does the clutch engage/disengage well in higher gears - test it in higher gears at lower speed - run through all gears up and down
    * Forks - Bring a clean rag, wipe the fork pistons before taking it for a ride or checking, hold front brake, push down firm a couple of times on the bars, is there any excess oil? do the forks compress easily, has teh buyer got info on changing/servicing forks etc? Any scratches/dings on the fork pistons? Also keep note that the rubber gasket on the fork seal which is visible is usually just a dust cap, and not the actual seal (which is concealed)
    FFFFffffuuuuuuux999
  9. #9
    far out man thanks heaps!
  10. #10
    anything i should know about clutches on a bike?
    expensive to replace? how do i know they're going?
  11. #11
    ...ZzzzZzzz Array
    Aug 2005
    Pushbike...
    same as a car, they will slip a bit... can become costly with labout, depends on the bike though
    FFFFffffuuuuuuux999
