Page 1 of 2 12 LastLast
Results 1 to 12 of 15
    Installation DC5R Oil Temp & Pressure
    Went to see my Auto Sparky today about getting these installed on the A Pillar the follow week i get my DC5R back now im wondering has anyone had these installed?? Was it a major hassle to get them done??
    My sparky has told me with my car theres little room (which there is) and it could be a problem and a mechanic may need to finish the installation of putting a sump in or something like that...
    Anyone installed had these 2 electronic gauges without a problem?
    If there was a problem, please explain it.
    Thanks
    Jan 2008
    John St, Cabramatta
    DC5R
    Usualy place i seen them mounted is above the a/c knobs.
    Quote Originally Posted by r3ckless View Post
    Don't want em there...
    A-Pillar there going on like the S15.
    I've seen em on my mates DC2R and they look good as.
    Newcomer Array
    Dec 2009
    Brisbane
    S
    in qld i got defected for having A pillar gauges. its a danger to the driver incase of an accident.
    have you got an oil cooler?
    not 2 my knowledge.. Mine will be setup so they can't be defected so yeah,
    Newcomer Array
    Dec 2009
    Brisbane
    S
    ok thats good.
    well if u got track ambitions get an oil cooler. then if u get an oil cooler u get a sandwhich plate. if u get a sandwhich plate u can put sensors in... get the picture.?
    Yeah got ya.
    Im plannin to track the car.. an oil cooler necessary for track or not?
  8. #8
    Mar 2008
    Sydney
    Bangbus
    Quote Originally Posted by WATAJK View Post
    A-pillar guages are illegal fullstop so I don't see how you can "setup so they can't be defected" but good luck with that
  9. #9
    Quote Originally Posted by geeang View Post
    ahh ok, oh well still going put em there Don't wanna put em on the centre console..
  10. #10
    Aug 2008
    NOR
    DC2R, EK1
    Yeah got ya.
    Type R pressures get extremely high, would recommend if you want to go hard without worrying so much. I'm doing same setup, just get a sandwich plate and your set.
    edit: Also seen the gauges on a DC5 mounted on dash with cup holders, doesn't look bad
  11. #11
    Nov 2006
    Melbourne
    DC5, EF8, EF2
    Quote Originally Posted by xtan View Post
    You mean temperatures get extremely high? I have heard oil temperatures around 120-130 degrees C measured at the sandwich plate mentioned by friends with gauges, which some people would call excessive. Pressure will decrease as the oil gets hotter and decreases in viscosity.
    Yeah got ya.
    I wouldn't say that an oil cooler is essential for light track use. Of the guys I know only one or two run oil coolers and we have many hours of track time in DC5s between us. I personally have around 2000 track kms on my car with no oil cooler and 130,000 total and I have had no issues whatsoever even in the heat of summer. Rather than spend the money on the cooler you should use the best synthetic oil of the correct viscosity that you can afford, change it very regularly and monitor your oil levels very closely when you are at the track.
    I use Red Line 10W-40 and 10W-30 oils and I have used Motul 300V in the past also.
  12. #12
    Thanks for your input ChargeR, really useful information!
