so this morning i picked up a set of integra blades. i got geed on painting them matte black + fixing the little gutter scratches on them. so at 3pm i got started.. and this is what ive done so far..........
shit you may need
-flat head screwdriver
-sandpaper wet/dry
-80 grit
-120 grit
-180 grit
-400 grit
-Primer
-Paint color of ur choice
-Newspaper/Marsking tape
-carbi cleaner
REMOVE THE WHEEL WEIGHTS FIRST! (if any...)
Ok first i cleaned all the wheels with carbi cleaner....
then got the 80 grit to sand down the larger scratches
then the 120 grit over the scratches
then a 180 grit over the entire wheel....
THIS TOOOK AGESSS!!!!!!!!!!!!!
then i laid some newspapers
let out air on the tyres
put newspaper around it, taped up riped parts with marsking tape
sprayed the shit with primer
finished primin them all ,,, then it got tooo dark! so ill spray the black on 2moz when der super dry!
ok so i forgot to remove the weights..
"The wheel weights are put on AFTER the tire is inflated while it is on a spin balancing machine. While there is a "special tool" for just this purpose (removing and installing the weights) they can be worked off with careful prying with a flat bladed screw driver. To reinstall them, make sure the "U" shaped clip that goes over the tire rim is not opened up, place the weight in the desired location, and then TAP it on over the rim of the wheel with a small hammer, or hammer and a small flat bladed screw driver placed where the weight meets the clip. (The "special" installation tool is essentially just a small hammer with a narrow head.)"
ok got the weights off... resanded those parts with 80 grit....wiped it down with a wet cloth. dryed it...then reprimered it...
luckly one of my rims didnt have weights on it..
so i sanded that with 400 grit
then wiped it down with a wet cloth,,,
then dryed it
then sprayed the matt black on!
i took the pic after like 1 or 2 coats
just finished them all
B4
AFTER
