since you are going to remove the carby head which incorporates the fuel pump, you will either have to convert to efi or get a "Facet" electric lift pump. Unsure whether or not the intake flanges are the same, will check it out.
Heyyy, cheers for the reply
so it is possible to keep it as a twin carb if I get a facet fuel pump???
