1. Check the brakes/ rotor condition. See if they squeal when you brake at moderate speeds. Def do a few hard brakes.
2. Check all lights are working (including back license plate ones). All brake lights, windows, side mirrors, tail lights, indicators, high beam, interior lights, CD player, aircon, Both Honda keys to lock/unlock/open boot etc...
3. Tyre wear (tyres are expensive especially as you go up in size)
4. Check the engine oil colour (make sure its not black)
5. Check exhaust muffler tip to ensure its in tact.
6. Look for any paint jobs (could've been from accident)
7. Look out for any steering issues (try roads flat and curved) This is a MUST
8. Make sure all doors open/close properly
9. Ask for when the last car was serviced (logbook is highly preferred)
10. Check all fluid levels topped up date (coolant/engine oil and filter (last replacement)/steering/ clutch if MT)
11. Check for any missing bolts near the tyre to see if the bumper had been removed for a bumper replacement due to an accident or whatever
12. Look closely for dings and little scratches
13. Listen to the motor run and give it a few good revs to listen to the sound
14. Drive sharp corners at moderate speeds if tyres are decent and at a speed the owner wont be shitting their pants
15. Make sure no lights come on after you have started your car (ie. VSA or any of the warning lights on the dash)
17. The VIN number is on the top right hand side so thats a must check
18. Ensure you can drive it in manual mode by shifting the "D" to manual and test out Vtec at 5500-6000RPM woooo. Oh and that idle RPM is at around 800-900 RPM on Neutral / Park
19. Good luck and don't expect the first one to be the one you buy. I would give a few euros a look before buying and you'll be able to compare the way that the car handles. My gf has an 06 Euro whilst I have an 03 Euro. They're both CL9s except her car feels a lot heavier and "euro-like". But it just comes to personal preference I guess.
