Results 1 to 7 of 7
Thread: b18cr dizzy
    Apr 2009
    adelaide
    97 ek4
    b18cr dizzy
    hi so my 98 spec b18cr distributor is making loud rattling noises so im guessing is on its way out. when you put your ear to the dizzy you can hear the bearing noise inside..i am planning on replacing with king distributor from usa a lot cheaper and better , i hear from this forum than oem..b4 i order i am right by saying i have ob2a arent i ? ..thanks
    Green block gangster Array
    twin GX160's
    yes you should mention to them you have an OBDIIa engine
    Oct 2004
    Sydney - Cabramatta/Liver
    Jazz EVO IX
    easiest way is to look at the dizzy it will have a part number.
    Match it to Dizzy King's unit.
    should be one of these
    TD81U, TD84U, TD86U, TD87U. It will be stamped on the dizzy
    Evo IX - THE FINAL EVOLUTION
    Jan 2006
    Ya mum's house in Brissy
    MY11 GTI, DA9
    Leighton T. aka LTPICS MSN=DEMON83_INC@HOTMAIL.COM
    '80 Accord 3D Hatch>'02 VW Golf S>'00 EM1 B18cR>'09 SYM Red Devil + '04 DC5R
    for sale= http://www.ozhonda.com/forum/showthread.php?t=127617
    Not many aftermarket options are "better" than OEM Honda, but most are certainly cheaper.
    Apr 2009
    adelaide
    97 ek4
    many thanks pm sent
    Hurstville
    jazz
    bumping old thread
    guys, i too have noisy dizzy and sounds like lightning crackling+metal on metal knock, when it started i was told its the dizzy bearing, noise get worse over time then i changed to new non oem dizzy. noise still there but not as loud, i was told it could be worn dizzy slot on camshaft or loose timing belt?
    any thought?
