Tein Hydraulic much expensive than the AirRunner and so much hassle for installation
TEIN Hydraulic only $1000 extra, for me if you ready to spend $5k better just put an extra $1k for the TEIN,
even Dedy @ Top One recommend the TEIN after he installed one last Sat for the E51, even there was a lil bit of problem with the Hydraulic coz the owner bought it 2nd hand so NO manual at all . . .
but he keep saying it its much better then any air suspension . . .
For my case I can't use tein hybrid because you need to drive at the lowest position & only raise it up if there's a speed hump or steep driveway. I want to drive at normal height & have flexibility to lower & raise the car. If you still need good handling then tein hybrid or air tank cylinder is the best option.
you still can drive at normal height, just set the coilover on normal height position, then if you want to show it off can be lowered to about 10 cm I have heard .........
