Page 3 of 7 FirstFirst 123456 ... LastLast
Results 25 to 36 of 83
  1. #25
    Jan 2010
    ACT
    DC2
    yeah you gotta take into account things like the air temperature on the day it's done can change your output quite easily. also I've read that different dynos usually come up with different results. :S
    -ZAMMIN-
    - Integra-GSi 19/11/2015
  2. #26
    Moderator Array
    Apr 2008
    '90 EF8/'94 EH9
    Not B18 I know but I just wanted to join the fun
    EF8 CRX
    Standard/unopened JDM B16A
    I/H/E consisting of:
    OEM intake arm with ghetto metal extension for CAI
    RS*R 4-2-1 header 2" outlet
    Stock cat
    2" press bent/mild steel cat-back
    5Zigen muffler
    99.4kw ATW
    30~ odd degree day, lots of other participants making 'normal' readings.
    Did a leak-down test later and found out the engine was making pretty much new compression at 98,000 genuine KMs
  3. #27
    Nov 2009
    Civic EJ8
    correct, dynos shouldnt be seen as a good solid measurement, each dyno varies, some maybe by 20% compared to others, dynos are nothing more than diagnostics an tuning tools, but often give a indication of the power of the vehicle, to gain true value of a engines power, you will need a engine dyno, which is taken off the flywheel....
    But alot of the figures seen is quite impressive, makes me think in the future mite just drop in a vtir motor instead of ITR cause of the price
    I <3 BOOST! D16+T SOHC
  4. #28
    Jan 2008
    legtec @2psi
    dyno run my dc2 long time ago
    121.5kw with stock intake 4-1 headers, 2.75inch catback but thats a b16/b20 engine
  5. #29
    Nov 2008
    99 DC2 VTi-R
    when mine was stock the dyno read 91.9kw @ 140xxx kms
  6. #30
    Aug 2008
    Vic
    DC5R
    dc2 vti-r with i/h/e 103kw
    Vtec4lyf
  7. #31
    Sep 2008
    Croydon/Denistone East
    b20 dc2
    98 vtir
    n/a b20
    154.4 fwkw
  8. #32
    Jan 2010
    ACT
    DC2
    Max 109.6kw at 8300RPM
    '95 DC2 VTi-R
    BCIII+ Cams
    ITR Valvesprings
    2.25" Xforce headers/cat/exhaust
    Hondata S300
    not a massive improvement on the MAX figure from before cams and tune, maybe gained 14kw? but low and mid range gained a fair bit as apposed to before and a really good torque increase. but holy sh*t the power curve is straight as! there's like no kinks in it like before, which is the real upside of the BCIII's I guess, and you can really feel the power just keep picking up as you go higher in the RPMS. VTEC crossover is not very noticeable sound-wise, which is good as I've read this means the transfer point is perfect.
    do keep in mind this is with stock intake and manifold only with a K&N in there, and stock injectors, so it's not really getting the air/fuel it need to get the most out of the cams. this will be MUCH improved when I get the rest of the bits for my ITB setup. (injectors, pump, FPR and a bunch of fittings and it's ready to go)
    I might post up the dyno graph when I get a scanner hooked up to my computer lol
    -ZAMMIN-
  9. #33
    Jan 2008
    legtec @2psi
    Quote Originally Posted by danny_2132 View Post
    98 vtir
    n/a b20
    154.4 fwkw
    Thats crazy power man ! good results. what is the setup mate?
  10. #34
    Sep 2008
    b20 dc2
    forged bottom, bigtubes, highflow cat, 60mm catback, 68mm tb, blox b cams, cam gears, gears, cai, fuel reg, fpr... 6-7 months of suffering
  11. #35
    Jan 2008
    legtec @2psi
    now would you ever go back to a b18 again ?
    thats great result for toda dyno, as its a pretty accurate one.
    any plans for 1/4 mile?
    what compresssion on the bottom end and piston type ?
  12. #36
    Sep 2008
    b20 dc2
    might go wsid tomorrow night...
    not sure on the compression 85mm toda.
