from my previous experience with my FD1, just take off the positive leads from your battery terminal and put it back, that will reset it and engine check should be off. try it once or twice.
If you were to get a pod small enough to fit in the factory air box, it wouldn't be a good thing. Chances are the surface area wwould very nearly be reduced. You're better off just getting a decent panel filter, like a k&n
Did it come with the piping/fittings for the jazz or just the pod? If it did then its just a matter of removing the stock airbox and putting the new one in.
yeh almost w.e
if u go to some of those japanese/ asian auto shops that sell stickers n stuff they sometimes have the pipe n pod just need to cut a small circle out and silicone the AMF sensor into it
