Would the oem 4.7 final drive from dc2r fit b16a\b18c2 box?
Ok, FD is interchangeble between all B18C/B16B - as ben says for the '98 Spec ITR box.
All EK9/ITR LSD's are the same. The ring gear difference is between the B16A (small diff) and B16B/18C (large diff).
The '98 spec difference is with the countershaft, as the '98 spec uses a slightly different fitment 1st gear.
B16A
B16B/B18C/B18C '98 Spec
Reason: Clarification - Mistake in original post
