Did you check/replace the TB gasket when you did the clean?
Did you also give the IAC (Idle Air Control) a good clean? This one is important when cleaning the TB
Is your PCV (Positive Crankcase Ventilation) valve clogged?
Is the throttle cable properly lubricated and not sticky? is the tension set correctly?
And as others have been saying, it may be a vacuum leak. You can check for a leak if you cover the throttle body opening with your hand while the engine is running and see if the engine cuts off. Try to be careful though, the vacuum pressure is quite strong.
