Results 1 to 7 of 7
    Apr 2007
    VIC
    07 CBR600RR
    Misc oil change Qs for 08 CBR600RR
    Hi guys,
    I'm epic noob when it comes to bike maintanence. I need to change my oil. It's been a bit over 5000kms. Some questions:
    - What oil should I use?
    - Where do I buy it from?
    - What oil filter should I use?
    - How much do I need to strip the fenders to change the filter?
    - How much time will it take me in total to change oil/filter?
    - Any special tools required?
    Thanks for your help all!
    ~ RoNi
    maybe you should take it to a shop since you said you're an EPIC NOOB and you dont want to stuff up ur 15k odd bike
    i recommend SPM
    4 Toorak Ave. Taren Point. NSW. 2229
    T. (02) 9531 6580 E. sales@spmotorcycles.com.au
    You know you want too... Array
    Sep 2005
    Sydney
    DC2R + VT750c2
    i went to Honda and got the oil and the filter from there...
    the filter was stupid expensive for its size (like 25 or something) and so was the oil. I bought Honda oil and it was like $70 for 4 litres. But you may be able to get a generic oil but they didnt have the right viscosity for mine
    I recommend you give it a shot yourself... do you know where the filter and the dran etc is? maybe you can find a manual online?
    - not removed by choice! - waiting for the next update to the saga
    http://www.ozhonda.com/forum/profile...=ignore&u=6316
    Newcomer Array
    Jan 2009
    Canberra
    *09-CU2-Lux-6MT
    Definitely Use Motul full synthetic, and original Honda Filter.
    Dont mess around with cheaper oils they will screw up your engine.
    Thanks
    Vid
    Dec 2008
    Sydney
    01 S2000
    Quote Originally Posted by RoNi_SiZe View Post
    Hi guys,
    ~ RoNi
    Oil choices in order of awesomness* and price.
    Motul 300V
    Motul 7100 full synth
    Motul 5100 Semi-synth
    *I would just use 5100 unless you race every day. Price difference of like $20 between the 7100 and 5100. If you change oil enough 5100 will do. Just my opinion. Weight should be 10-40.
    Any filter will do, some recommend use genuine Honda...but I don't think it makes a difference. For the price I'd prefer buy a K&N filter they have a socket thing on it to make for easier changes. No point telling where to buy cause I don't know where you live...I get my stuff from MCAS at Auburn.
    You need to take off both fairings. They should come off with an allen key.
    Takes about 1 hour or so of steady paced working. Start to finish.
    You need a 1/2" socket set, a small funnel unless you have good aim, an extension for the ratchet to reach betwen the headers to undo the drain bolt/sump plug.
    How much oil =
    2.8L with filter change
    2.6L withuot filter.
    I assume you know that the oil needs to be warm/hot when drained. Just adding, after you fill it up run it. Let it cool and then check level again.
    James
    Apr 2007
    VIC
    07 CBR600RR
    Thanks, jbird!
    That's all the info I need =)
    I think I will try it myself. Gotta start somewhere right?
    Cheers all,
    ~ RoNi
    Dec 2008
    Sydney
    01 S2000
    No worries. It's not heaps hard.
    If you've done a car before, you shouldn't have a problem.
    Lube the chain whilst your at it.
    One other thing I would check at 5000kms...take the lid off your airbox and just lightly tap out any large obstructions on your air filter. No doubt theres a couple of dead bugs and what not.
