A guy on this forum crashed "both" of his Integra's due to suspension, he cut them just to lower it and make it look fancy.
He lost control of the car when he was conering at a high speed, because when he was turning left the LHS tyre started to scrape on the guards,
this caused him to go straight into another car, and the 2nd incident he slid and hit a tree, because his turning cycle was rubbish, and there was no stability at all from the suspension.
His cars are a "ride off". But it's good that he learn't his lesson the hard way,
So please man don't do it, work for cash, sell shit, go do drug dealing or whatever just don't do this stupid way of lowering lol.
As others have said, why do people bother with this dodgy shit still?
You can pick up a set of lowering springs to suite your car (king springs etc) for way under 400 bucks these days.. why would you want to **** with your car, your life and other peoples lives?
Cutting/Torching your springs is so ****ing obvious and makes your car look so ****ing stupid and is STUPIDLY DANGEROUS IMHO.
In my eyes you shouldn't even have your car if your going to give it that sort of treatment but thank god you haven't done it yet.
If you wanna lower it/slam it just buy some ****ing king springs or get your current springs compressed. That's the cheapest option i'd go. By going this route you it'll actually sit better, not as bumpy compared to cut/torched springs and will have less cop attention.
You can pick up an angle grinder for 80 bux . Not even.
Only cut springs if youre car is a display car that wont get driven. That is the only time I can recommend cutting springs. Other than that. Never.
Theres a reason why springs have that number of coils.
If you look at lowering springs they should have around about the same amount of coils.
Go get your current springs compressed or go get king springs.
Go to a tyre joint that does suspension. They should hopefully point you in the right direction
Get King springs. They're only around $100 for 4 second hand!!!!
Ebay it if you want. You can get some pretty cheap and safer things on there. Please don't be stupid dude... The worse case isn't you killing yourself - It's you killing other innocent people from being stupid.
Don't do it.
If all you want is for the car to be lower, and don't care about anything else (seems like your mindset) then do the following - It's safer than what you are thinking of...
Gather some bricks. Fill the boot with them. This will lower the rear. It's adjustable too - Just like coil-overs. Just add more if too high, and take some out if too low.
