Page 46 of 62 FirstFirst ... 364344454647484956 ... LastLast
Results 541 to 552 of 733
  1. #541
    Quote Originally Posted by simmy View Post
    Hey fellas, just a quick question.
    if i run 17 x 8 +32 wheels with 225/45 on stock height/no guards rolled.
    will i have problems? i've had a quick look in this thread, and issues i may expect is just full car/dips or potholes
    most probably if i hit a big dip/bump.
    how about full car?
    need quick response please, thanks heaps in advance, will give rep.
    Depends what car. But you'll be fine!
    Try going for 215/45/17 instead.
    My front wheels are like that. no problems
    Also, Does anyone know the Coilover Spring Size for the 8th Gen Civics?
    Thinking about putting Stiffer springs on my HKS Coilovers
  2. #542
    Honda Civic FN
    Quote Originally Posted by lukits01 View Post
    Car Model: FN2 (Stock)
    Front Wheel and Tyre Size: 18x7.5+55 and 225/40/18
    Rear Wheel and Tyre Size: 18x7.5+55 and 225/40/18
    Suspension: Stock/coils
    Guard Modifications: None
    Issues with Setup: None
    Car Model: FN2
    Front Wheel and Tyre Size: 18x7.5+30 and 225/40/18
    Rear Wheel and Tyre Size: 18x7.5+35 and 225/40/18
    Suspension: 2.5deg camber front, stock rear
    Guard Modifications: The front was helped by running -2.5 deg camber but still needed some cutting of the guard liner and trimming of the fenders.
    Car Model: FN2
    Front Wheel and Tyre Size: 17x9+45 and 245/45/17
    Rear Wheel and Tyre Size: 17x7.5+35 and 225/45/17
    Car Model: FN2
    Front Wheel and Tyre Size: 17x8+38 and 235/45/17
    Rear Wheel and Tyre Size: 17x8+38 and 235/45/17
    Guard Modifications: The rears really sit flush with the guard, it was rubbing the guard by some 2mm which I trimmed off. The front was helped by running -2.5 deg camber but still needed some cutting of the guard liner and trimming of the fenders.
    Car Model: FN2
    Front Wheel and Tyre Size: 16x8+38 and 225/50/16
    Rear Wheel and Tyre Size: 16x8+38 and 225/50/16
    Quote Originally Posted by anaesthetics View Post
    How do 17's look on the FN2 compared to the stock 18s? Can't find a picture of one. I'm looking at getting one and have some 17x8+42 CR Kais I'd be interested in fitting.
    those will fit fine
    though 17s look rather tiny on a FN2
    Quote Originally Posted by alan View Post
    Car Model: FN2
    Front Wheel and Tyre Size: 18x8 +45 215/40
    Rear Wheel and Tyre Size: 18x8 +45 215/40
    Suspension: stock & coils
    Guard Modifications: none
    Issues with Setup: no issues
    Front Wheel and Tyre Size: 19x8.5 +35 235/35
    Rear Wheel and Tyre Size: 19x8.5 +35 235/35
    Suspension: stock
    Issues with Setup: slight rear scrub on extreme bumps, fine with passengers
    Front Wheel and Tyre Size: 18x7.5 +45 225/45
    Rear Wheel and Tyre Size: 18x7.5 +45 225/45
    Issues with Setup: none
    Front Wheel and Tyre Size: 17x8 +40 215/45
    Rear Wheel and Tyre Size: 17x9 +38 235/40
    Suspension: stock
    Issues with Setup: slight scrub in rear on extreme bumps
    Front Wheel and Tyre Size: 17x9 +44 225/45
    Rear Wheel and Tyre Size: 17x9 +44 225/45
    Suspension: coils
    Front Wheel and Tyre Size: 17x9 +22 235/45 (semi)
    Rear Wheel and Tyre Size: 17x9 +22 235/45 (semi)
    Suspension: coils
    Issues with Setup: front clears, rear sticks out about 1in each side
    Suspension: coils
    Issues with Setup: waiting for tyres
    Also tried:
    Front Wheel and Tyre Size: 17x9.5 +35 255/40
    Rear Wheel and Tyre Size: 17x8.5 +40 225/45
    Suspension: coils
    Issues with Setup: rears fit easy, front stick out a cm or 2 on each side
    Quote Originally Posted by androo View Post
    I'm currently running:
    Not 19's, but I can't imagine you having much issues if you go with lower profile tires. Plenty of guys running 19's in the UK. I'm running:
    Car model: FN2
    Front Wheel and Tyre Size: 18x8+40 and 225/40/18
    Rear Wheel and Tyre Size: 18x8+40 and 225/40/18
    Suspension: Stock
    Issues with Setup: n/a
  3. #543
    Honda Civic EP
    Quote Originally Posted by Philip Lee View Post
    i'll play:
    Car Model: EP3 (Stock)
    Front Wheel and Tyre Size: 17x7+45 and 205/45/17
    Rear Wheel and Tyre Size: 17x7+45 and 205/45/17
    Car Model: EP3
    Front Wheel and Tyre Size: 17x8+38 and 215/45/17
    Rear Wheel and Tyre Size: 17x8+38 and 215/45/17
    Suspension: Stock
    Issues with Setup: pretty much the most agressive offset without more -ve camber
    Car Model: EP3
    Front Wheel and Tyre Size: 18x7.5+42 and 225/40/18
    Rear Wheel and Tyre Size: 18x7.5+42 and 225/40/18
    Suspension: Stock/Coils
    Quote Originally Posted by RPS.13 View Post
    test fitted my new wheels today: BBS mesh 16x7.5 +24, 205/55/16
    quickly bolted these up today, before I put them back on the 180 and sold them with it
    shame I can't keep them and shame I didn't have time to lower the ep first...
    17x9 +30, 215/45 yoko s drives
    fitted my new wheels today... thought I'd post up some pics and info for reference...
    Rays Gram Lights 57s 16x8 +38, 205/55/16, stock suspension, unmolested guards
    Yep they are r33 GTR wheels, 17x9 +30 offset... aka "GTR offset"
    Not sure if they scrub on the inner arms, or guard liners as I never rolled on that set up. I only bolted it on to take a pic. (They didn't foul on anything when bolting them up).
    I have purchased another set though, since selling the 180 & I've only bolted up one on the front of the car so far after lowering it. I put 215/45/17 yoko S drives on them all round. With the current height I'm at (approx 1 finger between the guard and tyre) the wheels stuck out about 25-30mm? The corner/edge where the side wall meets the tread sits almost flush with the guard, sticks out about 3-5mm. I'm sure with the car a little lower and about 1.5 neg camber it should tuck in nicely. I'm assuming it will rub on the guard liners on the front. Rears I'm waiting to roll the rears first, install the coilovers and camber arms, before I put them on. Only trouble I can see would be clearance on the rear trailing arms.
    a 17x9 +30 compared to your 16x8 +30 (+15 effective offset)
    inner clearance: 28mm less
    outer position: retract by 2mm
    I guess check your inner clearances and go from there, atm your effective offset sticks out 2mm more than the r33 gtr wheels. So nah they won't be hanging out too far... Unless you're planning on getting a 9" rim in a lower offset?
    Not sure what car ur referring to though, but I assume its a dc2r? or maybe u have a ep3?
    Any pics of your current wheels, on the car?
    Quote Originally Posted by TOUGE-ITR View Post
    Hey man, yeah it's for an ep3. I've rolled the fron and rear guards already.
    When u say retract outer position by 2mm, do you mean it won't hang out as much from my current setup by 2mm?
    I'll take a pic when I can, probably this afternoon.
    Is that a 215 on the 9" rim? I was thinking of running 205/35 or 40. How much of a stretch was it?
    Will it need start-ya-bastard to get it on? Lol.
    Correct, it won't hang out as much as your wheels by 2mm.
    Yep I was/am running a 215/45/17 on the 9' rims... Mild stretch imo. I've also run a 215/40/17 on the same rim, similar amount of stretch, just looks smaller (I ran them on the front of the 180 to stop the scrubbing issues).
    205/40's on a 9" rim is a fair stretch, I don't think I would feel safe rolling on a 35 profile tyre! (hard cornering, hitting a pot hole etc)
    There some pics in here http://www.tyrestretch.com/
    of a 205/40/17 on a 17x9, you'll be able to see the edge of the tyre is more vertical, the rim protector bit will sit further away from the rim lip. Where as a 215 will curve slightly over the rim lip, that's if the tyres have those rim protector bits. The amount of stretch will also be dependant on what brand tyre u use, some will run wider than others in the same size.
    I'd go a 205/45, if you really want to get a 205... at least that way you'll be closer to having your speedo almost correct.
    That size looks to be fine, from what I have seen already on some EP's set up for grip... Similar setup's I have been looking at were a 17x9 +35, one was running 235/45's the other 245/40's. Both have rolled guards all round.
    The 17x8.5 +31 will sit in, retract by 2mm compared to the 17x9 +35. The tyre/wheel will sit quite flush with the front guards, the of amount poke/flushness will be dependant on what height and camber your at. More if your higher, less if your lower etc...
    I am in the process of fitting my 17x8 +38, 245/40's to the front of my EP, will get back to how it goes in regards to how it handles/performs. I reckon a 235/45 on the 8.5 should be pretty sweet!
    Quote Originally Posted by b16a2 View Post
    Car Model: EP3R
    Front Wheel and Tyre Size: 17 x 9 + 30 , 235/40/17
    Rear Wheel and Tyre Size: 17 x 9 + 30 , 215/40/17
    Suspension: Coilovers
    Guard Modifications: Rear Guards rolled, Front Guard to be rolled as it scrubs from time to time.
    17x8 +30 will sit flush to slight poke, depending on your final height and camber. You should be fine running the 225`s. I'd look into getting rear camber arms to correct your negative camber. Fronts you most likely will need a roll, and maybe trim the splash guards.
    Only pics i have for reference:
    17x8.5 +31, unsure of tyre size and camber. Your potential set up will sit in/retract 5mm compared to above.
    17x8 +38, 245/40, i was at approximately -1.0 camber. Your set up will sit out a further 8mm compared to the enkei`s.
    Rears i don't have any good pics at similar height, for reference.
    Here's a pic from ephatch.com
    17x8 +38 with 235/45/17. Mild drop with ~1.1 degree camber. Your set up will sit out a further 8mm, running the 225`s you may need to dial in -1.5 maybe more to tuck the tyre in.
    Quote Originally Posted by Symphorced View Post
    Running 17x9 +20 with 215/45/17 all round.
    Got a new set of wheels/tyres coming in for track setup the next few weeks:
    17x9 +35 245/40/17
    17x8.5 +30 225/45/17
    Will be interesting to see what I need to run them. Panel beater said he can space my guards for me if I need more clearance. Hoping to run no more than -2.5 degree camber at the fronts but should have enough adjustability to go to -3.5 if I need to. Not sure how well that will go for handling though. Time will tell!
    Quote Originally Posted by martymil View Post
    Car Model: 2004 EP3R
    Front Wheel and Tyre Size: 18x8 +45 225/40/18 continental Contac 3 Sports
    Rear Wheel and Tyre Size: 18x8 +45 225/40/18 continental Contac 3 Sports
    Suspension: Bilstein Shocks stock Springs Whiteline adjustable 24mm rear swaybar
    Guard Modifications:None
  4. #544
    Honda Civic FD
    Quote Originally Posted by Stig View Post
    I'll start with some of mine
    Car Model: FD
    Front Wheel and Tyre Size: 17x7+45 and 215/45/17
    Rear Wheel and Tyre Size: 17x7+45 and 215/45/17
    Suspension: Stock, Spring, Coils, Bags
    Car Model: FD
    Front Wheel and Tyre Size: 17x7+55 and 225/45/17
    Rear Wheel and Tyre Size: 17x7+55 and 225/45/17
    Suspension: Stock
    Issues with Setup: Cannot run with coils
    Car Model: FD
    Suspension: Stock
    Car Model: FD
    Front Wheel and Tyre Size: 20x8.5+45 and 225/30/20
    Rear Wheel and Tyre Size: 20x8.5+42 and 235/30/20
    Suspension: Springs and Coils
    Guard Modifications: Rears Rolled
    Issues with Setup: Front rim runs too close to the coils for comfort
    Car Model: FD
    Suspension: Coils
    Car Model: FD
    Rear Wheel and Tyre Size: 18x8.5+42 and 235/40/18
    Suspension: Coils
    Guard Modifications: Rears rolled
    Front Wheel and Tyre Size: 19x8+38 and 225/35/19
    Rear Wheel and Tyre Size: 19x9+38 and 225/35/19
    Suspension: Coils
    Guard Modifications: All round rolled
    Issues with Setup: Rear scrubs with car bumper, solution, more camber?
    Front Wheel and Tyre Size: 19x9+38 and 225/35/19
    Rear Wheel and Tyre Size: 19x8+38 and 225/35/19
    Suspension: Airbag
    Issues with Setup: Rear scrubs with car bumper, solution, 215 on the rear
    Quote Originally Posted by rk 86 wa View Post
    Car Model:fd
    Front Wheel and Tyre Size: 17 X 7 +42 215/40R17 toyo tasw
    Rear Wheel and Tyre Size: 17 X 7 +42 215/40R17 toyo tasw
    Suspension: stock
    Guard Modifications:n/a
    Car Model:fd
    Front Wheel and Tyre Size: 17 X 7 +42 225/45 R17 re001
    Rear Wheel and Tyre Size: 17 X 7 +42 225/45 R17 re001
    Suspension: coil 0 deg fr 2 deg r
    Car Model:fd
    Front Wheel and Tyre Size: 18 X 7.5 +42 235/40R17 regal some shit
    Rear Wheel and Tyre Size: 18 X 7.5 +42 235/40R17 regal some shit
    Guard Modifications: diy roll the inner tab
    Issues with Setup: still scraped
    Car Model:fd
    Front Wheel and Tyre Size: 16 X 6.5 +52 225/50/R16 D01g Semis
    Rear Wheel and Tyre Size: 16 X 6.5 +52 225/50/R16 D01g Semis
    Guard Modifications:diy rolled
    Issues with Setup: too big a tire for the rim
    Car Model:fd
    Front Wheel and Tyre Size: 16 X 6.5 +52 215/45/r16 ku36
    Rear Wheel and Tyre Size: 16 X 6.5 +52 215/45/r16 ku36
    Suspension: coil 0 deg fr 2 deg r and coil 2.5 deg fr 2.5 deg r
    Issues with Setup: rolling dia too small, not as much gained on track by smaller rolling dia as i thought there would be.
    Car Model:fd
    Front Wheel and Tyre Size: 17 x 7 +42 215/45/r17 A050 Semis
    Rear Wheel and Tyre Size: 17 x 7 +42 215/45/r17 A050 Semis
    Suspension: fr: -2.3 r:-2.0 Castor: 7-8mm Toe: 0
    Issues with Setup: ****ING PERFECT
    Also spacers used on +52mm 16" rims and they all fitted but ****ed my bearings
    Quote Originally Posted by ekdez View Post
    Car Model: FD on HRE reps
    Front Wheel and Tyre Size: 19x8 +45 225/35r19
    Rear Wheel and Tyre Size: 19x8 +45 225/35r19
    Suspension: stock
    Issues with Setup: stock front perches were scrubbing on bumps, offset too high.
    Car Model: FD on Rays ce28's
    Front Wheel and Tyre Size: 18x8.5 +30 225/40r18
    Rear Wheel and Tyre Size: 18x9.5 +25 245/40r18
    Suspension: coil-overs
    Guard Modifications: all guards rolled.
    Issues with Setup: tires scrubbed HARD over bumps, tire width too wide.
    issue was eliminated later on with 215/40r18's, they are my friends wheels!
    Car Model: FD on Vertini Henessy lolz
    Front Wheel and Tyre Size: 20x8.5 +42 235/30r20
    Rear Wheel and Tyre Size: 20x8.5 +42 235/30r20
    Issues with Setup: don't even bother.
    Car Model: FD on BBS LM's
    Front Wheel and Tyre Size: 18x8 +35 225/40r18
    Rear Wheel and Tyre Size: 18x9 +35 225/40r18
    Issues with Setup: tires scrubbed over bumps, tire width too wide.
    Car Model: FD on SSR Vienna Kreis
    Front Wheel and Tyre Size: 18x8 +38 215/40r18
    Rear Wheel and Tyre Size: 18x9 +38 215/40r18
    Issues with Setup: no issues.
    Front Wheel and Tyre Size: 18x8 +35 215/40r18
    Rear Wheel and Tyre Size: 18x9 +35 215/40r18
    Issues with Setup: very minimal scrub on front under hard cornering.
    Car Model: FD on Work T1S
    Front Wheel and Tyre Size: 19x8.5 +25 215/35r19
    Rear Wheel and Tyre Size: 19x9.5 +30 215/35r19
    Issues with Setup: ill let you know how i go =]
    Quote Originally Posted by eNGee View Post
    Car Model: FD on DC5S rims
    Front Wheel and Tyre Size: 17 x 7 +45 and 225/45/17
    Rear Wheel and Tyre Size: 17 x 7 +45 and 225/45/17
    Suspension: Stock
    Quote Originally Posted by aero View Post
    Car Model: FD on SSW s076
    Front Wheel and Tyre Size: 19 x 8.5 +35 and 235/35/19
    Rear Wheel and Tyre Size: 19 x 8.5 +35 and 235/35/19
    Suspension: Stock
    Guard Modifications: guards rolled
    Issues with Setup: scrubbing with full load and hard turning. tyres were too wide as well
    Car Model: FD on Lenso Type M
    Front Wheel and Tyre Size: 18 x 8 +45 and 225/40/18
    Rear Wheel and Tyre Size: 18 x 8 +45 and 225/40/18
    Suspension: coils
    Car Model: FD on work cr kai reps
    Front Wheel and Tyre Size: 18 x 7.5 +42 and 225/40/18
    Rear Wheel and Tyre Size: 18 x 7.5 +42 and 225/40/18
    Suspension: coils
    Issues with Setup: none. will switch to 215 tyres when current ones wear out
    Quote Originally Posted by jpestrada115 View Post
    Car Model: FD
    Front Wheel and Tyre Size: 18 X 7.5 +45 225/40 R18 92W
    Rear Wheel and Tyre Size: 18 X 7.5 +45 225/40 R18 92W
    Suspension: stock
    Quote Originally Posted by evolution View Post
    Car Model: FD1 on Work Emotion (Forged)
    Front Wheel and Tyre Size: 17 x 7.5 +30 and 215/45/17 Toyo Proxies 4
    Rear Wheel and Tyre Size: 17 x 8.5 +33 and 225/45/17 Dunlop Direzza
    Suspension: Tein Lowering Springs
    Guard Modifications: Rear guards rolled
    Issues with Setup: Only Rear scrubbing with full load and hard turning. Waiting for SPC front camber bolt and Ingalls Rear Camber Kit to see if more -ve camber will fix it
    Quote Originally Posted by liquid23 View Post
    Car Model: FD2
    Front Wheel and Tyre Size: 19x8.5 +43 / 225/35/19
    Rear Wheel and Tyre Size:19x8.5 +43 / 225/35/19
    Suspension: stock
    Guard Modifications: roll back guards
    Issues with Setup: nothing
    Quote Originally Posted by Riviera View Post
    Car Model: FD
    Front Wheel and Tyre Size: 19x8.5 +43 / 235/35/19
    Rear Wheel and Tyre Size:19x8.5 +43 / 235/35/19
    Suspension: stock
    Issues with Setup: scrubbing over small bumps in the front and rear splash guard front bumper to body mount in the rear
    Solution: get 225 for some angle on the sidewall also looks better... then some suspension mods
    Car Model: FD
    Suspension: stock
    Issues with Setup: when the car starts getting a bounce on like the highway scrubs in the front on the splash guard fixings
    and in the rear. scrubs on the bumper to body mount, although its hard to get the rear to scrub had full car also...
    Quote Originally Posted by ylo00w View Post
    Got it now and is fitted already. I try to get some pis tomorrow. Very happy with the stretch look aswell
    specs:
    17 x 8 rims 45offset
    215/45 rubber
    lowered on Tein Htech springs
    no issue at all
    thinking of 17x8.5 +30 on 205/40/17 OR 17x9 +35 on 215/40/17
    so far guards have been rolled and im on coils.
    how bad will those set ups be on scrubbing? u rkn i can carry a passenger or two in the back lol?
    which would be the most preferable for the minimalist amount of headache?
    17x8.5 +30 on 205/40/17 will give you least headache
    Quote Originally Posted by threesix View Post
    18x9's on the back of mine and i cant have anyone in the back seats. guards rolled too.
    im now on 215/40/17 tyres on a 17x9 +35 rim with a mild guard roll and dropped on coils. no scrubbing.
    im riding on 17x9 +35 right now with no issues on inner clearance. on coilovers and 215/40/17s tho. i think that if i were to run 235s on em there would probably be some issues with inner clearance and guard scrubbing.
    Quote Originally Posted by black8thgen View Post
    18x8 +45 on coils should be fine yeh? but people have said 45 offset is bad... why so??
    +45 isnt bad unless ur go any wider than 8". then u'll probably run into inner clearance issues. but 18x8 +45 just wont compliment the look of the car as much, since it will sit a fair bit inside the guards. i think flush fitment looks much better. gives cars better stance
    if you're talking about the gold work meisters in 18x8+45, i've been running them for about a week one thing i can say, no scrubbing ftw (1 finger tyre tucked)
    have u had people in the back yet? last year i was running 235/40 tyres on a 18x7.5 +42 rim (old set of tyres that came with the rims) and it scrubbed every time i did left turns and on dips. later i put on some 225s and there were no scrubbing issues at all even with a full car load and lowered suspension. also had 235s on 19x8.5 +35 rims and that scrubbed a bunch on stock suspension with just one person in the rear.
    Quote Originally Posted by aznboiio1 View Post
    will 18 x 8 +44 fit for fd2?,
    planning to run buddyclub n+ coils in the future
    Quote Originally Posted by patchwick View Post
    should be ok, i've got 18x8.5 +47 on coilovers .. no issues
    update since i last posted...
    Car Model: FD on Enkei RPF1
    Front Wheel and Tyre Size: 17 x 9 +35 and 215/40/17
    Rear Wheel and Tyre Size: 17 x 9 +35 and 215/40/17
    Suspension: coils
    Car Model: FD on Rota Grid
    Front Wheel and Tyre Size: 18 x 9.5 +30 and 235/40/18
    Rear Wheel and Tyre Size: 18 x 9.5 +30 and 235/40/18
    Suspension: coils
    Issues with Setup: Lots of scrubbing everywhere. most likely from the chunky tyres. only had them for a couple of days, but im pretty sure with some 215/40 or 215/35 stretched tyres + camber arms, i could have pulled it off lol.
    Front Wheel and Tyre Size: 17 x 9 +25 and 215/40/17
    Rear Wheel and Tyre Size: 17 x 9 +20 and 215/40/17
    Suspension: coils + rear camber arms
    Issues with Setup: none... but 2 defects lol
    Quote Originally Posted by .k. View Post
    Front Wheel and Tyre Size: 17 x 8 +35 and 205/40/17
    Rear Wheel and Tyre Size: 17 x 8 +35 and 205/40/17
    Suspension: coils
    Issues with Setup: none... bar defect for too low
    Quote Originally Posted by kaitoudark View Post
    I got my wheels installed.
    18x8 +40 offset Enkei GTC01 with 225/40R/18 Bridgestone RE002.
    Fits perfect. Only minor issue with hitting the humps too hard though. My wheels hit the fender.....
    What should I do? Will having coils solve the problem? Do I need to roll my fender?
    Quote Originally Posted by DuffyFD View Post
    On my FD
    I'm running 17x8 +30 205/45R17 with 20mm spacers on front, on coils and have only a little scrubbing with guards half rolled. I could roll them completely flat and flush, but i'm already cracking paint so that can wait.
    I'm running the 17x8 +30 215/45R17 on the back, rolled as much as I could, only scrub on the back bumper screw when there's more than 2 in the car.
    Quote Originally Posted by ekay1 View Post
    Car Model: FD1
    Front Wheel and Tyre Size: 17 x 9 + 38 , 225/45/17
    Rear Wheel and Tyre Size: 17 x 9 + 38 , 225/45/17
    Suspension: coils
    Guard Modifications: guards all rolled
    Issues with Setup: fat tyres scrubs on the rear screw like no tomorrow when there are people in the car. Offset is too high, too close to the strut and has created a hole in the fuel line plastic cover.......
    Quote Originally Posted by Areis View Post
    Car Model:civic fd 08
    Front Wheel and Tyre Size: BBS LMs 17x8 +20ish 225/45/17
    Rear Wheel and Tyre Size: BBS LMs 17x8 +20ish 205/45/17 (and a 20mm spacer)
    Suspension: Tein stech springs, hardrace camber arms
    Guard Modifications:rolled rears
    Issues with Setup: scrubs on hard bumps and turns. doubt i can have anyone in the back seat. looking to fix it hopefully with more guard work.
    Quote Originally Posted by hiepness View Post
    Currently running this on FD2 Sport.
    BBS LMs
    Rear: 17x8 +45 225/45 KUMHO
    Front : 17x8 +40 225/45 KUMHO
    Was wondering if i can run springs with no rub or nething?
    Cz right now on stock suspension is fine. but i wanna get some Tein Springs.
    Car model: FD2 Sport
    Front Wheel and Tyre Size: 17x8+40 and 225/45/17
    Rear Wheel and Tyre Size: 17x8+45 and 225/45/17
    Suspension: Lowered on Tein Springs (25mm Drop)
    Issues with Setup:I guess it rubs when you drive into the holes on the road. apart from that. All sweet.
  5. #545
    ... Just to save people going through the 500 odd posts.
    There is a lot more information in there, I've purely quoted the informative posts, there are some post throughout the pages where its been chit-chat over 5 posts with "should be" "maybe" "could" but no definite, I haven't quoted those.
  6. #546
    Good work on collating all that info lolmclol
    Found a handy "Wheel Fitment, Tyre Stretch, Rolling Radius and Speedometer Error" calculator, which allows you to kind of visualise how your new wheel/tyres will sit, in relation to your old wheel.
    http://www.willtheyfit.com/
    Please take note of the note about the positioning of the strut: The strut shown in the diagram is for show only - Don't worry if the wheel looks like it fouls!
  7. #547
    Awesome link! Very Helpful.
    Now i can physically see where the rim will be
  8. #548
    May 2011
    FD1
    Car Model: Civic fd1
    Front Wheel and Tyre Size: XXR 521 16x8 +20/+5 195/45/16
    Rear Wheel and Tyre Size: XXR 521 16x8 +20/+5 195/45/16
    Suspension: 1.5' dropped springs
    Guard Modifications:All rolled
    Issues with Setup: ???
    Anyone can help me out with this? I want to run 195/50 but afraid it might run heaps. Thinking of adding 15mm spacers on as well.
  9. #549
    Quote Originally Posted by Baygon View Post
    Should be fine. My friends FD had the same wheels and size. from the ground to his bumper was 4cm.
    No guard modifications and all Natural Camber. He didnt have any problems
  10. #550
    May 2011
    FD1
    Quote Originally Posted by Honda_FD View Post
    Thanks for the feedback, will test it out soon!
  11. #551
    Aug 2008
    EM1
    Quick question guys.
    Will 235/45/17 fit on stock EP3 wheels 17x7+45. Have an opportunity to buy a 2nd hand set for decent price. But after doing some research they may be too wide for stock wheels.
    Anyone have any experience with this size on a 17x7 wheel?
    "It's B1GTYM baby!!"
    3TripleZero
  12. #552
    Oct 2009
    head ache
    CL9
    once i hacked the fuel cell cover i was 100% gravy. 3 people in the back, no probs.
    wake up and take some sleeping tablets.
