Page 1 of 2 12 LastLast
Results 1 to 12 of 19
Thread: Hondata S300
    Jul 2005
    Melbourne
    EP3R K20
    Hondata S300
    Hi guys
    i got HOndata s300 on my eg with b18c7
    was try to set up the lunch control
    but it won;t activate,
    anyone got this problem on their S300?
    or how you turn it on
    cheers
    Sep 2007
    Sydney
    DC2 Squared
    Can you communicate with the S300 with no dramas?
    It's very straight forward, activate it, set the parameters and upload it.
    Green block gangster Array
    May 2004
    twin GX160's
    do you have a clutch switch installed
    Nov 2004
    Melbourne S.E
    HONDA
    i got the same problem too. how to set up the launch control
    May 2004
    twin GX160's
    im pretty sure you need a switch on your clutch pedal connected back to the ECU, so the ECU knows when to launch the car
    Ozhonda Supporter Array
    Jul 2004
    Brisbane
    MV Agusta F4
    Na you don't Ecu man. Well I think you can, but don't need. Its just a ignition and fuel cut at a pre-determined rpm. Theres are however number of settings.
    OP, see below. What have you got the Launch Activation set to? Always on? If its Always on launch control is alway activated, and will work when below the pre-determined vehicle speed.
    Deano.
    you need to first of all install clutch switch, then it needs to be configured in software.
    NA all the way, turbos are ghey.
  8. #8
    Jul 2004
    Brisbane
    MV Agusta F4
    You don't NEED a clutch switch as I said above. Mine was set as above. 'Always on', therefore anything below 10kph would activate launch control. Depends what the OP is trying to do, as yet he hasn't got back yet.
    Deano.
  9. #9
    ^ I can back this up, have had launch control set to always on and for it to be active as long as the vehicle is under 10km/h , set my desired rpm and works all day every day if I wanted it to
  10. #10
    Account Disabled Array
    Aug 2004
    Garage
    Make sure there isnt anything wrong with your VSS
  11. #11
    Jul 2005
    Melbourne
    EP3R K20
    HI guys, i am very sorry, completly forgot i got this post, lucky i search first, be4 i post the same question again,
    now what happen is i set the launch control to always on, set the limter to 8223RPM, activation rpm is at 4102RPM, fuel and igition stays at 0, am i doing something wrong? cos the launch control still not on, as i tired soma many times today,
    Hi Benson, what is VSS?
    any ideas?
    was doing the shift light at the same time today as well,got it working, but not the launch control,
    idea was got the feature, why not use it,
  12. #12
    Moderator Array
    Apr 2008
    Melbourne
    '90 EF8/'94 EH9
    vehicle Speed Sensor.
