Results 1 to 7 of 7
Thread: d16y1
    Newcomer Array
    Feb 2010
    newcastle
    dc5s
    d16y1
    just about finished engine swap d15b4 to d16y1 have noticed that the ecu code is p91 have looked on this site and can not find this any ideas
    Apr 2009
    QLD
    ED Sedan
    Quote Originally Posted by owens14 View Post
    should be P28 if you're planning on running the standard ecu. you sure you're reading the correct code?
    should look something like this--->
    Newcomer Array
    Feb 2010
    newcastle
    dc5s
    Thats what i thought the car that the motor came out of was running fine the ecu looked like orignal one there was a water leek and nuts were rusted on here is full code 37820-p91-000 736-7000862 awx
    Apr 2009
    QLD
    ED Sedan
    there a list here: http://www.hondata.com/techecuid.html
    but doesn't have any P91
    Newcomer Array
    Feb 2010
    newcastle
    dc5s
    its definetly a p91 and the ecu was running the vehicle
    Nov 2004
    Manly Yo
    ED/EG5/EP3/JAZZ
    P91 92-95 OBD1 JDM Civic Coupe (SOHC VTEC)
    Normally you'd be running a P28 with a D16Y1 as markismaximus mentioned
    I believe the JDM SOHC VTec had slightly more aggressive cams and possible a different VTec crossover point to compensate than the AUS counterpart
    Not sure what effect running a Jap spec ECU on a AUS spec motor will be though
    161.4KW ATW Tuned By TODA
    EG5 JDM B16A SiR-II TURBO
    13.28@106.6mph 2.117 60ft On RE001
    Newcomer Array
    Feb 2010
    newcastle
    dc5s
    Thanks not sure whats going on once the fuel tank comes in and is running its straight to the dyn
