Page 1 of 2 12 LastLast
Results 1 to 12 of 15
    Newcomer Array
    Mar 2009
    Ireland
    Accord Euro R CL7
    Pulling to the left
    Euro R 2003 ..
    Got 4 new Goodyear Eagles fitted recently and all of a sudden the car is pulling to the left when accelerating. No pull when braking. The alignment was corrected on all 4 wheels but problem is still there.No apparent wear is noticeable on the suspension bushes and joints.
    Can anyone help.
    Newcomer Array
    Jan 2010
    New Zealand
    Accord Euro
    Quote Originally Posted by DAVEURO View Post
    Euro R 2003 ..
    Can anyone help.
    If you have ruled out other factors such as unequal air pressures, suspension, bushes and joints then I would suggest that the alignment is not done correctly at the tyre shop. I have two occasions in hte past where wheel alignment has to be done a second time for the car to track stright becaue the first technician did not quite get it right first time.
    Newcomer Array
    Mar 2009
    Ireland
    Accord Euro R CL7
    Thanks ,
    The car is straight, suspension seems to be in order.
    Its just that on the old tyres which were badly worn and in poor condition the car drove perfect without pulling.
    I noticed in some other reports something about assymetrical directional tyres causing problems.
    The new tyres are Goodyear eagle F1 assymetrical 215/45/17.
    Aug 2004
    Sydney Harbour Bridge
    03 CL9 Euro
    the car general pulls to the left no matter what as it is to prevent oncoming collisions.
    You prob feel it more now due to the new tyres as your old tyres were worn in.
    Also are you testing it on a flat rd or cambered rd? As the euro stock alignment settings have been set to veer slight left in general to negate the camber in the rd.
    Hope this helps, also the euro tends to have tramlining.
    vTeK 4-Life!
    FOR SALE: CL9
    Jun 2006
    Fraser Coast
    MY12 CU2 Auto
    An old trick, swap your front tyres from side to side. If it then pulls in the opposite direction which is a good possibility, put the offending tyre on the back.
    Aug 2004
    03 CL9 Euro
    Quote Originally Posted by buddah51au View Post
    assuming your tyres are bidirectional.
    vTeK 4-Life!
    FOR SALE: CL9
    Jun 2006
    Fraser Coast
    MY12 CU2 Auto
    if they r directional swap front to back, or get the tryes turned around on the rim so they can be run on the opposite side. it s not all that uncommon for tyres to be the culprit.
  8. #8
    Oct 2009
    Perth
    08 Accord 2.4
    stop playing Beyonce on your stereo
  9. #9
    Mar 2009
    Northern Rivers, NSW
    MY05 WRX WRP10
    Quote Originally Posted by lefty View Post
    hahaha WHAT THE ^^^^
  10. #10
    Oct 2008
    Melbourne
    06 Euro
    trying using your right hand...or both, lol
  11. #11
    Newcomer Array
    Mar 2009
    Ireland
    Accord Euro R CL7
    Thanks for the replies,
    Its not the road camber because it will happen if i drive on the other side of the road.
    Im getting the suspension checked again and will try tyre rotation.
    I can now change lanes with my right foot .. Power on goes left , power off goes straight .Suspect lower arms are the problem.
  12. #12
    Aug 2004
    03 CL9 Euro
    expensive though like $20/wheel.
    vTeK 4-Life!
    FOR SALE: CL9
