Page 2 of 2 FirstFirst 12
Results 13 to 18 of 18
    atm it got 300mm disk diameter and my current rims are 5zigen 17in with a 43 offset and that just clears the brake calliper.
    ive tryed on the ce28 and they still hit the side of the callipers.
    starting to get really annoyed with the bumpy ride
    Jul 2005
    Western Sydney
    94 EG, 11 Maloo
    swap brakes with me?
    Power Of Dreams...
    VTECN
    Quote Originally Posted by vtekme View Post
    Just get a couple of spacers - just measure how much you need - usually 10mm should be enough.
    Don't use those generic spacers either, get specific machined ones so they centre on the hubs and the wheel correctly - should be around $150
    Also, with using spacer's you might need extended wheel studs.
    MFactory Competition Products
  4. #16
    Feb 2006
    sydney yo
    green whip!
    as above, can give wheelworx a call to see if they can supply you with some bolt on hubcentric spacers(eliminates the need to have extended studs)
    otherwise look into h&r spacers, specifically the drs system as i believe they come with extended studs(mine did anyway)
  5. #17
    You drive it like that? wtf.
  6. #18
    Aug 2006
    murarrie
    EG Si Hatchie
    bumpy ride can be from many things. damper rate? tyre pressure?
    can't believe you said you would get rid of the brakes. i'm heart broken. i'm killing for bigger brakes. i'm rolling stock 242's no worries under my 15" rotas. brake + wheel swap plz? i'll chuck in new slotted rotors
    Is this the end of my car modding days? Buying a house says so...
